mavik
#1 Posted : Tuesday, January 29, 2019 9:37:32 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
I'm using a title connected with a datasource. There is one column with a yes/no (or 0/1) entry. Like a switch. Is it possible to trigger this switch?
#2 Posted : Tuesday, January 29, 2019 10:18:27 PM(UTC)
as in to do what ? do something in the title or what ?
mavik
#3 Posted : Wednesday, January 30, 2019 12:43:52 AM(UTC)
mavik
Some speakers don't wont to be shown. Privacy stuff. If there is a No instead of a YES I want to trigger the lower third to be off and a holding slide with a text to be shown instead of the cam.
something like
If (NO) {
hide overlay 2+3;
show overlay 4;
} else {
hide overlay 4;
show overlay 2+3;
#4 Posted : Wednesday, January 30, 2019 5:02:22 AM(UTC)
Hmm
you could create a custom XAML LT with a fullscreen image holder imbedded and bind some data to a hidden/visible status of the image/LT data etc (and use the hidden/Visible word instead of yes/no)
edit: actually would work with 0/1
edit 2 : would need to use opacity rather than visibility (worked in Blend but not in vMix )
#5 Posted : Thursday, January 31, 2019 4:27:53 AM(UTC)
Here is a (very) rudimentary example xaml overlay title for this
- one "normal" lower third text
- one image place holder that will block the camera view (load your blocking image in it)
- one "dont want to be seen" text block
- one on/off textblock to show/hide the image plus no see comment to block seeing your guest (enter value 0 or 1 manually or through datasource)
HideGuest.xaml (3kb) downloaded 36 time(s).
mburel1980 on 2/1/2019(UTC)
Barney Box Lane
#6 Posted : Thursday, January 31, 2019 11:31:00 PM(UTC)
Barney Box Lane
does GT design have visible variables, so if the field is empty the graphic or image isn't displayed that's ultimately how you need to do that
#7 Posted : Friday, February 1, 2019 12:50:10 AM(UTC)
No not in such a way but with shortcuts you can show/hide a pages
Is basicly what i did as you state in the classical xaml title i posted before your comment
