I'm using a title connected with a datasource. There is one column with a yes/no (or 0/1) entry. Like a switch. Is it possible to trigger this switch?
as in to do what ? do something in the title or what ?
Some speakers don't wont to be shown. Privacy stuff. If there is a No instead of a YES I want to trigger the lower third to be off and a holding slide with a text to be shown instead of the cam. something like If (NO) { hide overlay 2+3; show overlay 4; } else { hide overlay 4; show overlay 2+3; }
Hmm you could create a custom XAML LT with a fullscreen image holder imbedded and bind some data to a hidden/visible status of the image/LT data etc (and use the hidden/Visible word instead of yes/no)
edit: actually would work with 0/1 edit 2 : would need to use opacity rather than visibility (worked in Blend but not in vMix )
Here is a (very) rudimentary example xaml overlay title for this - one "normal" lower third text - one image place holder that will block the camera view (load your blocking image in it) - one "dont want to be seen" text block - one on/off textblock to show/hide the image plus no see comment to block seeing your guest (enter value 0 or 1 manually or through datasource)  HideGuest.xaml (3kb) downloaded 36 time(s).
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
does GT design have visible variables, so if the field is empty the graphic or image isn't displayed that's ultimately how you need to do that
Originally Posted by: Barney Box Lane  does GT design have visible variables, so if the field is empty the graphic or image isn't displayed that's ultimately how you need to do that No not in such a way but with shortcuts you can show/hide a pages Is basicly what i did as you state in the classical xaml title i posted before your comment
