NDI
LattePanda Alpha 864
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
Looks interesting. Will require some kind of capture device. M.2 and USB are possibilities. Seems like a workable solution, give you can solve for a sensible enclosure and power.
It's a little costly compared to some other solutions, like a NUC. But it's smaller and perhaps has more CPU power.
Thanks: 2 times Was thanked: 46 time(s) in 32 post(s)
I think it should work. I have tested a similar board with way less cpu power, and it worked fine for 1 NDI encode + 1 decode with a capture card.
NDI
