spencerm24
#1 Posted : Saturday, September 30, 2017 6:50:26 PM(UTC)
spencerm24
Has anyone used the Behringer UMC1820 as an ASIO input device? Will it allow me to see and control all the inputs via vMix instead of the mixer itself? Any compatibility issues I should be aware of?
raugert
#2 Posted : Saturday, September 30, 2017 7:27:34 PM(UTC)
raugert
Canada
I use a UMC404 as an I/O with vMix and it works well. Make sure you install the drivers from the Behringer site. I'm not sure what you mean by 'control' the device ? The UMC1820 is an audio Interface not a digital mixer. VMix can see the inputs and outputs as audio channels and can adjust the levels within the vMix mixer. The input gains have to be set on the Behringer interface itself. Hope that helps.
thanks 1 user thanked raugert for this useful post.
spencerm24 on 9/30/2017(UTC)
spencerm24
#3 Posted : Saturday, September 30, 2017 7:36:16 PM(UTC)
spencerm24
Thanks, yes, thats what I meant by control, adjust the levels from the vMix program rather than the face of the unit. If it allows me 8+ analog inputs controllable via vmix, then this does what I want. Thanks!
Jav
#4 Posted : Monday, January 14, 2019 11:57:52 PM(UTC)
Jav
Spain
You can indicate if everything has worked well ?, I intend to buy this equipment to work with vMix
spencerm24
#5 Posted : Tuesday, January 15, 2019 12:06:15 AM(UTC)
spencerm24
Works perfectly! It's a great unit for audio.
ThomasK
#6 Posted : Tuesday, January 29, 2019 6:33:35 AM(UTC)
ThomasK
Austria
We also use the same Behringer unit, works flawless with vMix.
