Has anyone used the Behringer UMC1820 as an ASIO input device? Will it allow me to see and control all the inputs via vMix instead of the mixer itself? Any compatibility issues I should be aware of?
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
I use a UMC404 as an I/O with vMix and it works well. Make sure you install the drivers from the Behringer site. I'm not sure what you mean by 'control' the device ? The UMC1820 is an audio Interface not a digital mixer. VMix can see the inputs and outputs as audio channels and can adjust the levels within the vMix mixer. The input gains have to be set on the Behringer interface itself. Hope that helps.
 1 user thanked raugert for this useful post.
Thanks, yes, thats what I meant by control, adjust the levels from the vMix program rather than the face of the unit. If it allows me 8+ analog inputs controllable via vmix, then this does what I want. Thanks!
Joined: 6/29/2018(UTC) Posts: 19  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
You can indicate if everything has worked well ?, I intend to buy this equipment to work with vMix
Works perfectly! It's a great unit for audio.
Joined: 8/11/2018(UTC) Posts: 60   Thanks: 33 times Was thanked: 6 time(s) in 6 post(s)
We also use the same Behringer unit, works flawless with vMix.
