8 Pages«<45678>
Chircanu
#101 Posted : Thursday, January 17, 2019 6:37:08 AM(UTC)
Chircanu
Originally Posted by: SHMD Go to Quoted Post
Originally Posted by: admin Go to Quoted Post
vMix Beta 22.0.0.42 has been uploaded
* Added support for resizable VST3 plugins
Awesome!
Hello everyone, I want to test the Vmix 22 preview, but I have a problem. Does the software with the installed license somehow? Thank you in advance for your answer!
richardgatarski
#102 Posted : Thursday, January 17, 2019 7:42:32 AM(UTC)
richardgatarski
Rank:: Advanced Member
From the first post in this Preview topic:
"Updates: If you purchased vMix prior to 1 January 2018, an additional purchase is required to use this beta or a new Trial is possible if you haven't
used the Trial in some time. Finally, an edition upgrade (say from HD to 4K) will also include 12 months of free updates."
In other words, you might need to pay for the Update ($60) in order to run v22 (beta).
Chircanu on 1/18/2019(UTC)
seb666
#103 Posted : Thursday, January 17, 2019 7:47:52 AM(UTC)
seb666
* Support for Kona 5 added
How many 4K inputs can be used with a Kona 5? :)
#104 Posted : Thursday, January 17, 2019 12:06:09 PM(UTC)
Was thanked: 4741 time(s) in 1627 post(s)
The Kona 5 works similarly to the IO4K Plus, that is to say
port 1 is a 4K input port and port 3 is a 4K output port.
That means it only supports 1x 4K input or output.
There is OEM firmware available that turns it into a real 4x 4K input card
but it is not currently available to the public.
seb666 on 1/18/2019(UTC)
amonerdj
#105 Posted : Saturday, January 19, 2019 12:57:28 AM(UTC)
amonerdj
http://cdn.vmix.com/download/vmix22preview.exe
* Added Activators support for Stream Deck
* Fixed connection issues with Stream Deck
* Fixed audio issue with vMix AVI in Magix Vegas
* Fixed configuration issue with NDI sources in Replay
* Improved reliability of Sony VISCA over IP provider
* Number of GT fixes including zoom scrolling for 4K templates, image update, duration dropdown and data change animation issues.
* Latest NDI 3.8 fixes included
the NDI has problems in this version, it consumes more resources than the version 38 and the connections fall or have intermittence
MycroBeat99
#106 Posted : Sunday, January 20, 2019 3:37:52 AM(UTC)
MycroBeat99
Romania
Same for me, but i think the NDI 3.8 is the problem because if you have NDI Tools 3.8 installed, the other software which uses NDI automatically use more resources.
And i see this issue on all my computers with NDI 3.8 (1 with 21.0.0.60 and 2 with 22.0.0.42 and another NDI software installed for testing)
IrvinCee
#107 Posted : Monday, January 21, 2019 2:54:30 AM(UTC)
IrvinCee
There's an audio issue in .42 which I did not had in 38.
Everything sounds to slow, like there is a bitrate issue + skips.
Like when recording a 48KHz in 44.1 KHz.
When I listen to vMix master output all sounds at normal speed.
The stream itself sounds to slow and skippy.
You can listen here
https://www.facebook.com.../2268418186814103/?t=121
When people reported the issue I instantly reinstalled .38 and the issue was gone.
I'm using VST from waves if that is relevant...
UPDATE: I just reinstalled .42 again in order to reproduce the problem, but everything sounds ok now....
Maybe this is a castr issue?
My previous stream which I cut a couple of minutes before I started may be in 44.1 KHz.
I'll check that later on.
Greetings
amonerdj
#108 Posted : Monday, January 21, 2019 4:35:35 AM(UTC)
amonerdj
in none of the computers where I have installed the vmix beta is installed in NDI tools, and that's why I know the problem is in vmix
#109 Posted : Tuesday, January 22, 2019 1:03:45 PM(UTC)
For those seeing higher CPU with the latest NDI, can you try the following utility to see if it helps:
https://www.vmix.com/download/vMixNDIConfig.zip
1. Run the utility
2. Turn off UDP on send and receive and click OK.
3. Restart vMix and any NDI applications
If this works, it means UDP is causing the higher CPU usage.
UDP has some advantages including multicast support and lower latency, but it may use more CPU usage
as a result.
QuiapoChurch on 1/22/2019(UTC), seb666 on 1/29/2019(UTC)
ask
#110 Posted : Tuesday, January 22, 2019 1:21:54 PM(UTC)
ask
1. Run the utility
as a result.
Thanks Martin. Question: Does this set UDP usage for vMix only or will it set it for any NDI tool on the PC i.e.Studio Monitor?
#111 Posted : Tuesday, January 22, 2019 1:25:09 PM(UTC)
This tool enables/disables UDP functionality in NDI globally on the computer, so all
NDI apps will follow the settings applied here.
ask
#112 Posted : Tuesday, January 22, 2019 1:45:50 PM(UTC)
ask
Are there any other implications of this other than the change in CPU usage and latency?
roverradio
#113 Posted : Friday, January 25, 2019 5:02:15 AM(UTC)
roverradio
The new Pause on inputs works as expected. It seems to have no effect on vMix Call inputs though. Is that by design?
It would be most helpful if you could pause a vMix call (actually stop data transfer, not just pause the image). Those of us using satellite trucks would be most appreciative!
Ario
#114 Posted : Friday, January 25, 2019 7:30:02 PM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
Hopefully, this 'small task, big gain' request can be incorporated (or already has been?) in the vMix 22 release:
the highlight bar in the Instant Replay console is orange, and the checkboxes are red.
It is VERY HARD to see now, if a box is/is not checked, when the event is highlighted in orange, since the red-orange combo just does not contrast enough.
If check boxes could e.g. be made white, this issue would be nicely resolved.
Thanks !
And best of luck with the great new v22.
thanks 1 user thanked Ario for this useful post.
mburel1980 on 1/25/2019(UTC)
NHT
#115 Posted : Sunday, January 27, 2019 3:35:45 AM(UTC)
NHT
Unless I'm being stupid (a high possibility) the play/pause shortcut does not seem to work with camera sources.
Testrup
#116 Posted : Sunday, January 27, 2019 7:41:08 AM(UTC)
Testrup
Denmark
Hi Martin and Co.,
I've read the entire thread (all six pages) and can't find any information about whether it's "safe" to install the vMix 22 preview on the same computer as v21 is already installed?
In short: Can I have both versions installed on the same time without v22 interfears with v21 which we use in production?
Thanks for a brilliant piece of software.
Simon Testrup
LivePro
Denmark
NHT
#117 Posted : Sunday, January 27, 2019 9:00:27 AM(UTC)
NHT
Originally Posted by: Testrup Go to Quoted Post
Hi Martin and Co.,
Simon Testrup
LivePro
Denmark
Hi Simon, I wouldn't want to answer for Martin but I've had 21 and 22 running on the same machine since the Beta came out with no issues. I just made a different install folder and navigated to it when installing 22.
thanks 1 user thanked NHT for this useful post.
Testrup on 2/3/2019(UTC)
#118 Posted : Sunday, January 27, 2019 9:13:26 AM(UTC)
Dito
Hi Martin and Co.,
Simon Testrup
LivePro
Denmark
#119 Posted : Sunday, January 27, 2019 12:41:00 PM(UTC)
We setup a separate shortcut just for the live pause to prevent accidentally pausing cameras with existing shortcuts.
LivePlayPause
NHT on 1/27/2019(UTC)
goaliebob99
#120 Posted : Sunday, January 27, 2019 2:42:41 PM(UTC)
goaliebob99
I found another bug. Social 4 - Gordon Street Blue. When you save fromphoto.source and exit the program and reload the picture does not save in the photo box. Im having to reload the image every time.
8 Pages«<45678>
