Data Source Google Sheets ERROR
Hi All,
I have been using Google Sheets for quite a number of projects and this is a problem that has troubled me every time. Some of the time when a user updates the spreadsheet to updates instantly in vMix and without issue, But a lot of the time I get this error:
ERROR: the remote server returned an error: (429) Too Many Requests.
Could I have missed something with the api or setting something up incorrectly to get this so frequently?
I seem to remember that there was an issue with Google sheets and high volumes of transactions. Do a search on this forum.
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
It is not an "issue" it is by design to limit "free" account's requests. In your Google API console it says, how much requests you can make per day/100s. Also, each sheet will get seperate requests. For example, you have 5 sheets in a single spreadsheet document and you update it every 1000ms, it will make out to 5 requests per second.
You can easily upgrade to higher number of allowed requests. Check in the Api Console and Sheets API - Quotas.
