RobLambert
#1 Posted : Tuesday, January 22, 2019 7:52:45 AM(UTC)
RobLambert
Guys, has anybody used vMix to collaborate remotely to produce a professional grade album. If so, how is it working out?
Thanks for any input good or bad. How is the quality of the audio (per specs with a good fast connection it seems like it should sound as good as if it were being recorded in the room next door..... and that the key issue would be the quality of the equipment and engineer and NOT vMix or Skype....
I appreciate the help.
Rob
TuesdaysLive
#2 Posted : Tuesday, January 22, 2019 7:57:21 AM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
Your biggest issue, depending on distance, would likely be latency, opposed to quality.
mjgraves
#3 Posted : Friday, January 25, 2019 1:56:35 AM(UTC)
mjgraves
Actually, it's a little more complicated than that. You'd have to test to be sure.
vMix call uses WebRTC, which makes some presumptions about how to handle the audio. For example, it defaults to using noise reduction, auto gain control and echo cancellation.
It's possible for an app to turn the on/off individually. I'm not sure what vMix does. I know that it does not give you that control.
Latency is another issue. That will vary with your location and the other parties location.
It's doable, but you need to do some homework.
Some years ago my partner, a well regarded guitarist himself, interviewed a guy who had created a device to allow musicians to jam online.
https://www.vuc.me/2015/...ogether-live-on-the-net/
#4 Posted : Friday, January 25, 2019 2:31:50 AM(UTC)
For audio quality I'd go for ISDN-like services like
https://cleanfeed.net/
https://zencastr.com/
https://now.source-elements.com/
Not free :
https://www.ringr.com/
to name a few
Guillaume
mjgraves
#5 Posted : Saturday, January 26, 2019 3:14:40 AM(UTC)
mjgraves
Not free :
to name a few
Guillaume
It's worth noting that tose services are simple WebRTC applications build as ISDN replacements, so they treat audio differently. Same underlying tech, just exposed in a different manner.
mavik
#6 Posted : Monday, January 28, 2019 6:34:53 PM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
Just to add another WebRTC software that I use and can report good results with is from medialooks.
