GT
BUG: Shrink On Right-Justified Text Blocks
Joined: 7/15/2018(UTC) Posts: 110  Location: Las Vegas, NV Thanks: 14 times Was thanked: 9 time(s) in 7 post(s)
Found one!
Under "Configure automatic text box resizing", the setting "Shrink" does not work if the text is right justified.
Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4790 time(s) in 1644 post(s)
Just tested here and it is working. As a test I created a text field, set the font size really high, set it to right align then set the auto size mode to Shrink. Resizing the box changed the text size as expected.
Martin vMix
Hey Martin, Not getting the same results. Worth noting, I am using an Excel spreadsheet to update the text in the box. Attached both examples. Look for the text in the bottom right hand corner underneath the white box. Left justified shrinks the text, right cuts it off.
Can you upload a copy of the .gtzip template so we can take a look at it, or alternatively email it to us at info@vmix.com.auI just did another test with text fields configured in every possible layout format and the shrink worked as expected so not sure what is going on with the that template. Regards, Martin vMix
Rank:: Advanced Member
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
I can confirm that it's working.
Regards, Rudy
Sorry for the delay. Been out of work with Strep. Back tomorrow and will send you the link. Can assure you, only difference is the left or right justification and it is treating the text differently when right justified.
Here is the template, also emailed to you. The text at the bottom right hand corner.  Feed.gtzip (60kb) downloaded 7 time(s).
Thanks Shaun, I have found the bug which is related to word wrapping being disabled. This will be fixed in the next update.
GT
