shawntempesta
#1 Posted : Friday, January 11, 2019 11:32:34 AM(UTC)
shawntempesta
Was thanked: 9 time(s) in 7 post(s)
Found one!
Under "Configure automatic text box resizing", the setting "Shrink" does not work if the text is right justified.
#2 Posted : Friday, January 11, 2019 11:53:13 AM(UTC)
Just tested here and it is working.
As a test I created a text field, set the font size really high, set it to right align then set the auto size mode to Shrink.
Resizing the box changed the text size as expected.
shawntempesta
#3 Posted : Saturday, January 12, 2019 9:22:43 AM(UTC)
shawntempesta
Hey Martin,
Not getting the same results. Worth noting, I am using an Excel spreadsheet to update the text in the box. Attached both examples. Look for the text in the bottom right hand corner underneath the white box. Left justified shrinks the text, right cuts it off.
#4 Posted : Saturday, January 12, 2019 5:33:26 PM(UTC)
Can you upload a copy of the .gtzip template so we can take a look at it, or alternatively email it to us at info@vmix.com.au
I just did another test with text fields configured in every possible layout format and the shrink worked as expected so not sure
what is going on with the that template.
rudyengels
#5 Posted : Saturday, January 12, 2019 10:58:48 PM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
I can confirm that it's working.
Rudy
shawntempesta
#6 Posted : Thursday, January 17, 2019 3:38:13 PM(UTC)
shawntempesta
Sorry for the delay. Been out of work with Strep. Back tomorrow and will send you the link. Can assure you, only difference is the left or right justification and it is treating the text differently when right justified.
shawntempesta
#7 Posted : Friday, January 18, 2019 10:43:41 AM(UTC)
shawntempesta
Here is the template, also emailed to you. The text at the bottom right hand corner.
Feed.gtzip (60kb) downloaded 7 time(s).
#8 Posted : Friday, January 18, 2019 12:29:22 PM(UTC)
Thanks Shaun, I have found the bug which is related to word wrapping being disabled.
This will be fixed in the next update.
stigaard on 1/18/2019(UTC)
Guest (5)
