Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
I just had a slight panic prepping for a job when my machine refused to record Prores.
I kept getting the message 'raw video format not supported'.
After some head scratching I checked the secondary recorder which was indeed set to a lossless format BUT the enable box was unticked.
I tried changing the secondary record to mp4 and still got the error message.
Then restarted the machine and it recorded Prores fine.
I don't really want to mess with the machine to try to recreate the problem at the moment, sorry.
