Joined: 10/17/2018(UTC) Posts: 22  Location: Rawang Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
Hi, I want to use my Vmix for my live tv channels 24/7, MCR(Multi Control Room). I want to set up with 2 system. 1 for the live 24/7 and one more pc for standby incase the 1st system failure. How can i do the switching or swap my backup system. Sorry for my bad English.
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
vMix is not a playout solution for 24/7 operation vMix is a live production software
Originally Posted by: DWAM  vMix is not a playout solution for 24/7 operation vMix is a live production software He's right, vMix is not designed for this use, so use at your own risk. that being said, theres lots of ways to switch the system over, if you're streaming, utilize the backup stream key provided by facebook and youtube. If not streaming and delivering this over SDI, AJA makes a product that can automatically switch over if it detects no video on one input. A simple patch field or BNC Jack field can do this manually. Lots of options, just depends on budget and how automated you want it to be. but again, vMix is not designed for this so you use at your own risk.
Originally Posted by: DWAM  vMix is not a playout solution for 24/7 operation vMix is a live production software Noted. Any suggestion for the best solution playout system? Thank You.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 75 time(s) in 57 post(s)
 1 user thanked stevespaw for this useful post.
