With the upcoming multiview feature of vMix 10 and the great shortcuts available within vMix, it might be useful to have 3 or 4 "folders" to organise your inputs. In my own (admittedly limited) broadcasts, I get up to about 20 including all the titles and saved replays I use. Some use cases I can imagine are:
1) Camera/Capture inputs displayed on multiview and switched with keyboard, so don't need to be in the main input area and can be hidden. 2) All delay inputs (and saved delay footage) in a single folder together, so are easily accessible for quick replay 3) Organise pre-rendered graphics and titles so a particular folder can be used during particular parts of the broadcast 4) Hide shortcut-triggered or multiview only inputs away so they don't clutter up the input area (Stingers, replay bugs, that sort of thing)
Basically the intention is to clear the input area so that only the inputs you need at that point in time are in front of you. For instance, in the kind of broadcasts I do, I know in the first segment I'll need my main RTSP feed (My main camera), an intro video, some pre-recorded interviews, league standings and a previous matches graphic, and some lower thirds.
Then once the match starts, I'll need my three RTSP feeds (Main camera + 2 more secondary), Video Delay inputs of those three feeds, a scoreboard, some lower thirds, and access to my replay stinger. In vMix 10 I'll probably have the RTSP feeds through the multiview, so won't need to see them in the input area most of the time. Most of the time I'd want to have the delays and the saved footage from the delays all in reach.
And again at the end I'll have my main RTSP feed, some lower thirds, the saved footage for replaying, updated league standings and an upcoming matches graphic and an outro video.
So for me, I'd use 3 or 4 folders to organise my broadcast, and help keep the input area clean and uncluttered.
Does that make sense?
Cheers! Grimble.
+ 1 I have alluded to this before and agree that it would help with "Screen Estate". Well thought out Grimble! However,I also believe that the development of a functional and programmable hardware switcher may reduce the immediate need for such modifications to the GUI if it can be set up to accomplish the objectives you outline.
I'm personally unlikely to purchase a hardware switcher, much though I'd like to, so I'd rather have improvements to the core program for now. :)
Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
+1
Folders to organise the various inputs would be amazing.
Even though with the upcoming vMix 10.1 it is getting better regarding the saved Delay-Clips there still are a lot of other inputs which could be organised.
Joined: 1/13/2010(UTC) Posts: 5,374  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
I'm looking into some sort of input organising feature for a future release.
One possible idea is to have a colour coding system with Red, Green, Blue and All toggle buttons. All would show all inputs as they are now and the other buttons would show inputs that have been allocated to a particular colour.
What do you guys think?
Martin vMix
for me that should work as well
one colour for the "Standard"-Inputs, one for Titles of the Home-Team, one for the Titles of the Away-Team.
Would be great to get such a feature...
This is what it looks like at the moment. To move an input to a colour category, drag it over the button. What do you guys think? admin attached the following image(s):  colourcoding.jpg (42kb) downloaded 57 time(s).You cannot view/download attachments. Try to login or register.
Joined: 8/3/2013(UTC) Posts: 30   Location: SW England Thanks: 12 times Was thanked: 4 time(s) in 4 post(s)
yes Martin I think that would be a very good idea. With a bit of planning, (say a show notes worksheet or "running order" that allowed you to quickly see when to bring up the next relevant set of inputs and hide the current ones) you could then drastically reduce the number of inputs that needed to be on show at any one time.
Peter
How are the folder colours affected by and/or different from the program and preview colours?
The folder colours are completely separate, the colours above each input remain the same depending on active/preview etc.
That looks great Martin. Maybe also number the tags as well, so Red-1, Green-2, Blue-3 etc, and have the number superimposed on the button. That way a rundown or workflow can reference the tag easily. Also, extensible so you could have up to say 9 colours/tags.
Also, could an input have multiple tags? So if you have an input that is shown in the Red set, it can be in the Blue set as well.
This is my first day of really getting to know vMix and some of its quirks. (I'm a VidBlaster convert.) Working with many inputs (overlays and spots for playlists) creates an endless scroll of sources, which when you're needing to find something fast, isn't going to happen. Being able to organize the inputs by folders (as well as control the order inside the folder) would be super.
