jj_82
#1 Posted : Wednesday, January 9, 2019 9:24:34 PM(UTC)
jj_82
Germany
i like to have an overlay graphic or video on top of a stinger transition.
Is there a possibility?
Best regards
#2 Posted : Wednesday, January 9, 2019 11:50:32 PM(UTC)
no
elvis55
#3 Posted : Thursday, January 10, 2019 4:32:26 AM(UTC)
elvis55
Switzerland
#4 Posted : Thursday, January 10, 2019 5:54:22 AM(UTC)
Originally Posted by: elvis55 Go to Quoted Post
am i missing something ?
Where does it states one can have a overlay (like logo ) on TOP of a stinger ??
A stinger is the top most layer so while you might have a logo or title (overlay) remaining while transitioning it still will be behind the stinger
jj_82
#5 Posted : Thursday, January 10, 2019 7:21:08 AM(UTC)
jj_82
Germany
Hallo zurück.
Ich weiß wie ich einen Stinger einrichte.
Das funktioniert auch.
Was ich gerne hätte, wäre ein Dauerlogo welches über dem Stinger liegt.
Hierfür habe ich aber bisher keine Lösung gefunden.
Außer einer zweiten vMix Instanz mit dem NDI Output der ersten Instanz und dem Logo als Quellen.
Sozusagen eine zweite M/E bzw. einen Submixer.
@doggy
Yes, this is my problem. I like to have a Stinger under an animated Logo. But i can‘t find a Solution.
#6 Posted : Thursday, January 10, 2019 7:30:54 AM(UTC)
es gibt keine (standard)
only workaround i can think of is if you have the logo incorporated in your stinger file(s), in case of animated i guess one would notice a skipping or something
oops , i stand corrected , making a multiview (add logo layer) of the stinger input might work , but duration could be an issue
#7 Posted : Thursday, January 10, 2019 7:43:35 AM(UTC)
actually it kind of works if :
- have your logo set as overlay and set to loop (uncheck automatically play/pause)
- add the logo input as multiview layer to your stinger input
- have the duration of your stinger set to a very looooooong time as it otherwise will stop playing the animation anyway ( static logo less of a problem)
personally dont see the point of having this on top of your stinger but hey ...
elvis55
#8 Posted : Thursday, January 10, 2019 8:31:36 AM(UTC)
elvis55
Switzerland
Hallo,
Ich bin mir nicht sicher, ob ich das richtig verstehe. Habe mich bis jetzt auch nicht gross mit Stinger befasst.
Du willst ein dauerhaftes Logo, zb. oben rechts? Ich habe bis jetzt das Logo immer mit Overlay integriert.
Ich hoffe, ich verstehe das richtig?
Habe jetzt mal einen Test gemacht.
Input hinzufügen - Bildsequenz/Stinger - ein Logo.png hinzugefügt. In Overlay Einstellungen (unten rechts) auf Nummer: Stinger 1 - Typ: Picture in Picture - Effect: Cut - Effect Dauer: 1000 - Dauer: 1000 Frames - Stinger Input: das Logo.png - Stinger Schnitt Position: 1000 Frames - Bild in Bild Position: das Logo platziert. Ok klicken.
Dann überblendung des Videos oder der Kamera von Preview zu Output mit dem Stinger 1 gemacht.
Dann Overlay Einstellung wieder geöffnet und bei Dauer und bei Stinger Schnitt Position 0 Frames eingestellt. OK klicken.
So wird jetzt bei meinem Test das Logo immer angezeigt, egal welche übergang ich verwende.
Bei mir funktioniert es, hoffe bei anderen auch.
Gruss
I'm not sure I understand that correctly. I have not dealt with Stinger until now.
You want a permanent logo, eg. top right? I have always integrated the logo with overlay so far.
I hope I understand that correctly?
Have now made a test.
Add Input - Image Sequence / Stinger - a Logo.png added. In Overlay Settings (bottom right) on Number: Stinger 1 - Type: Picture in Picture - Effect: Cut - Effect Duration: 1000 - Duration: 1000 Frames - Stinger Input: the Logo.png - Stinger Cut Position: 1000 Frames - Picture in Picture position: the logo is placed. Ok, click.
Then crossfade the video or the camera from preview to output with the stinger 1 made.
Then overlay setting reopened and set at duration and stinger cut position 0 frames. OK click.
So now the logo is always displayed in my test, no matter what transition I use.
It works for me, I hope for others too.
Greeting
#9 Posted : Thursday, January 10, 2019 8:44:12 AM(UTC)
negates the proper functionality of a stinger , switching input in the mids of an image sequence preferably in such a way you can not see the cut point as it mostly will be hidding by a full screenfill of one of the images ie purpose of a stinger
spencerm24
#10 Posted : Friday, January 11, 2019 12:10:55 AM(UTC)
spencerm24
Hallo zurück.
@doggy
not sure if this is what you're looking for, but could you not take the input that has the stinger, and add a logo in multiviewer? that way when it puts the stinger in, the logo is automatically put in as well.
