Hesadanza
#1 Posted: : Friday, September 20, 2013 6:16:09 PM(UTC)
Hesadanza
I'm trying to figure out why the new Logitech C930e is not working with vMix. I have the C920 too, and it works great. But the C930e has a very low frame rate, probably under 15 frames per second. I've tested the camera in other software, and it seems to work fine (30 fps). Anyone know what the issue might be?
Thanks.
peterphelan
#2 Posted : Saturday, September 21, 2013 4:14:50 PM(UTC)
peterphelan
Do you have them both plugged in together? It seems Logitech never realised their web cams would be used for live streaming and multiple camera setups; they were thinking single webcam on Skype or similar would be the only configuration needed.
So it appears even plugging the two cameras into separate USB busses, they will not work together. The control only adjusts the first cam to be set up and, as you have found, the whole quality etc is dreadful!
Peter
Hesadanza
#3 Posted : Saturday, September 21, 2013 4:25:25 PM(UTC)
Hesadanza
I've tried it both ways. I've tried both plugged in together, and plugged in separate. The C920 works like a charm. The C930e give a very low framerate. There must be some sort of incompatibility with the software. I don't have any such issues in Skype, Google Hangouts, etc., with the C930e, and it shows full 30 fps.
By the way, the controls work fine using the C920 and C930e together, since they use different software to control them. The different software works simultaneously to control each camera.
But the framerate on the C930e is the killer, if trying to use with vMix. Not sure why. Perhaps vMix can't utilize the built-in hardware H264/SVC compression of the C930e, or perhaps it is something to do with the UVC 1.5 encoding.
peterphelan
#4 Posted : Sunday, September 22, 2013 2:35:09 PM(UTC)
peterphelan
yes it seems there are problems using the 930e with VidBlaster too; same issues of frame rate, quality etc. But the c920 works just fine. I remember when Panasonic introduced the GS500 DV camera and people (who were expecting it to be an updated version of the GS400) were horrified to learn that this "new" camera actually had *less* facilities than its predecessor! (I still have my GS400)
Maybe the same kind of thing will happen here in that people go desperately searching for the "old" c920 to purchase, before it becomes completely unobtainable -:)
Peter
h2video.nl
#5 Posted : Monday, September 23, 2013 2:21:17 AM(UTC)
h2video.nl
are you using the c930 in win 8 or win 7? in win 7 you should have the option to run the camera with the build in drivers, not using the logitech drivers. maybe this would benefit vmix recording.
i am stll trying to figure out if i can run the c920 in windows using non logitech drivers, but it seems win8 works differently. you could consider a downgrade to win7 if this will make your cam work.
based on this discussion i quickly bought a second c920 although i was consideting a c930 because of the wide 90degrees angle of field.
stefan
fey13
#6 Posted : Monday, October 20, 2014 10:56:17 AM(UTC)
fey13
hello
Solved the problem with Logitech c930e ???
I connect 2 Logitech c930e today. Result - very low frame rate! At first glance, Full HD about 15 frames per second.
Other applications work well with this camera.
What could be wrong? Maybe there is a third-party driver?
Or using applications such "YouCam" solve the problem?
I tried SplitДam app and choose it as a source of "vMix".
This has no effect, anyway low frame rate.
Can someone use these applications to work with web cam?
Prompt, plz, and sorry for my English. ))
Windows 7 x64
vMix 14 (Trial)
allayit
#7 Posted : Monday, December 1, 2014 9:35:32 AM(UTC)
allayit
Same question as fey13.
Top end HP i7 laptop, 16GB RAM, 2 x 1TB SSDs, NVIDIA 635M graphics, etc.
Running Windows 8.1 Pro x64.
C930E works in other streaming applications without issue.
orlioe
#8 Posted : Tuesday, December 9, 2014 10:51:22 PM(UTC)
orlioe
When adding c930e try changing the video format from "Default" to "MJPG". You should get 30 fps. That worked for me.
Elitebook 8530p, Core duo 2.53, 4 GB, Windows 8.1 32bit
madness
#9 Posted : Wednesday, December 10, 2014 11:45:29 AM(UTC)
madness
From Good Webcams Post #6
admin wrote:
Try some of the different formats under the "Video Format" dropdown box in the Camera window.
vMix prefers high quality video formats which can have a slower frame rate on most webcams.
You can try lower quality options such as H264 or MJPG and see if they work. Note the H264 format has a delay
but this should be the same as other apps.
Similar Topics
vMix 24 Webcam Issue (Logitech c930e) (General Discussion)
by GeorgeR 1/28/2021 10:16:47 PM(UTC)
Logitech C930e won't add as camera in v21 (Hardware Compatibility)
by castfeeder 6/12/2018 1:58:51 PM(UTC)
Logitech c930e with greenscreen (Hardware Compatibility)
by bluelagune 9/29/2015 3:36:09 PM(UTC)
