AlanZ
#1 Posted : Friday, December 28, 2018 1:03:54 AM(UTC)
AlanZ
I have a need to create multiple snapshots with unique file names.
Currently I am using a shortcut that creates the unique name based on file date and time.
I used "C:\Users\myuser\pictures\snapshot {0:yyyy-MM-dd H-mm-ss.f}.png" as the value in the shortcut.
This works very well, creating file names like "snapshot 2018-12-26 21-36-47.1.png"
I am combining the snapshots into a time-lapse movie, so I need unique, sortable file names.
My question is whether there is a value that will increment a file name in much the same way that "new file every" does in recording capture.
I would like filenames to automatically increment as they are added... something like "snapshot00001.png", "snapshot00002.png"
Your thoughts are appreciated.
AlanZ
#2 Posted : Sunday, December 30, 2018 3:18:55 AM(UTC)
AlanZ
Anyone?
MartLeib
#3 Posted : Sunday, December 30, 2018 3:47:30 AM(UTC)
MartLeib
Views messages in topic : 189
Estonia
I would write a small script that renames all the files in a folder according to the creation time.
#4 Posted : Sunday, December 30, 2018 5:10:08 AM(UTC)
if all you want is it to be sortable the date you are using is already chronological not ?
and one could even simplify it say with just using the time , one can even omit the dashes like /snapshots {0: hhmmss tt}.png
else will need MartLeib's suggestion or use some (existing) mass file renamer
mjgraves
#5 Posted : Sunday, December 30, 2018 7:00:58 AM(UTC)
mjgraves
I use a very nice image management tool called ThumbsPlus. One of its many features is that it will auto-rename a sequence of pics, appending numbers after a prefix.
AlanZ
#6 Posted : Sunday, December 30, 2018 10:08:50 AM(UTC)
AlanZ
I appreciate the comments, but does someone know how to do what I asked?
The current naming does not pose a sorting issue for me... but I would prefer a simple sequence number without post processing of the files.
This way it could be easily turned into an image sequence when the capture is complete.
#7 Posted : Monday, December 31, 2018 1:43:36 AM(UTC)
@ AlanZ
How are you creating your Image Sequences now?
The vMix Image Sequence Input does this automatically with sequential images in a folder, is it that the timestamp is not recognized as a sequence?
AlanZ
#8 Posted : Monday, December 31, 2018 9:13:24 AM(UTC)
AlanZ
I was under the impression that vmix and some other programs expect sequentially named files when defining an image sequence. I don’t think they look at the file date/time to determine order.
AlanZ
#9 Posted : Monday, December 31, 2018 9:14:14 AM(UTC)
AlanZ
I am creating the files by taking snapshots in vMix, as stated in my original post.
AlanZ
#10 Posted : Thursday, January 3, 2019 3:14:54 PM(UTC)
AlanZ
Pinging the group again with the original question: Is there a shortcut value for a snapshot that will increment a file name in much the same way that "new file every" does in recording capture?
richardgatarski
#11 Posted : Tuesday, February 5, 2019 2:51:07 AM(UTC)
richardgatarski
Alan,
AFAIK it is not possible to add a sequence number field to file name templates in Snapshots, Recorder, etc.
I thought I made a Feature Request for that years ago, but can't find it.
daniel514
#12 Posted : Thursday, April 11, 2019 12:06:06 AM(UTC)
daniel514
Canada
Was thanked: 16 time(s) in 16 post(s)
AlanZ
If you code Python... or find a nice coder... you can probably get a script to capture your sequences as a timed delay if you do time-lapse.. and name your snapshots as you desire directly in Python...
I got SnapshotInput working as a weblink... cool!
For vMix 22!
Stored in C:\Users\YourUser\Documents\vMixStorage
http://localhost:8088/API/?Function=SnapshotInput&Input=1&Value=mysnapshot%20{0:yyyy-MM-dd%20H-mm-ss.f}.jpg
And this little Python 2.7 script ....
Code:
import socket
import time
s = socket.socket(socket.AF_INET,socket.SOCK_STREAM)
s.connect(("localhost",8088))
sleeper = 1 #Time to wait in seconds between snapshots!
SnapshotInput = "GET /API/?Function=SnapshotInput&Input=1&Value=mysnapshot%20{0:yyyy-MM-dd%20H-mm-ss.f}.jpg HTTP/1.0\n\n"
def your_function1():
		s.send(SnapshotInput)
		#s.close()
while True:
    your_function1()
    time.sleep(sleeper)
daniel514
#13 Posted : Thursday, April 11, 2019 12:54:06 AM(UTC)
daniel514
Canada
I like a lot ReNamer
AlanZ
#14 Posted : Sunday, April 14, 2019 2:20:23 AM(UTC)
AlanZ
As I previously mentioned, I am not having any difficulty converting the capture images into a time-lapse file. I “simply” was looking for an alternative to the date/time naming convention (at create time, not via post processing)
For anyone interested, here is my possibly unique use of vMix with an X-key controller to capture 3D print progress
RichShumaker
#15 Posted : Thursday, March 24, 2022 7:06:24 AM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
Just ran into this issue today.
I wanted to use sequential names like many other image programs offer.
So Image#####.png would give me a sequence starting Image00000.png Image00001.png Image00002.png.
But I was only able to come up with a date time stamped version.
What is that leading 0 in the name?
I was thinking the 0 was for numbering except mine keep coming out with the same number to start.
Since this is a test right now I wonder if later today it will change or if tomorrow it will be a different number.
#16 Posted : Thursday, March 24, 2022 9:00:47 AM(UTC)
is part of the String.Format method in .net
RichShumaker
#17 Posted : Tuesday, March 29, 2022 8:29:08 AM(UTC)
RichShumaker
Honestly I have no idea I just copied from the example to make sure I didn't mess it up.
mavik
#18 Posted : Tuesday, March 29, 2022 11:35:15 PM(UTC)
mavik
I use total commander for this task. It's a swiss army knife anyway.
Guest (9)
