Snapshot file naming for sequence?
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
I have a need to create multiple snapshots with unique file names.
Currently I am using a shortcut that creates the unique name based on file date and time.
I used "C:\Users\myuser\pictures\snapshot {0:yyyy-MM-dd H-mm-ss.f}.png" as the value in the shortcut.
This works very well, creating file names like "snapshot 2018-12-26 21-36-47.1.png" I am combining the snapshots into a time-lapse movie, so I need unique, sortable file names.
My question is whether there is a value that will increment a file name in much the same way that "new file every" does in recording capture.
I would like filenames to automatically increment as they are added... something like "snapshot00001.png", "snapshot00002.png"
Your thoughts are appreciated.
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
I would write a small script that renames all the files in a folder according to the creation time.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
if all you want is it to be sortable the date you are using is already chronological not ?
and one could even simplify it say with just using the time , one can even omit the dashes like /snapshots {0: hhmmss tt}.png
else will need MartLeib's suggestion or use some (existing) mass file renamer
I use a very nice image management tool called ThumbsPlus. One of its many features is that it will auto-rename a sequence of pics, appending numbers after a prefix.
I appreciate the comments, but does someone know how to do what I asked? The current naming does not pose a sorting issue for me... but I would prefer a simple sequence number without post processing of the files. This way it could be easily turned into an image sequence when the capture is complete.
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ AlanZ
How are you creating your Image Sequences now? The vMix Image Sequence Input does this automatically with sequential images in a folder, is it that the timestamp is not recognized as a sequence?
I was under the impression that vmix and some other programs expect sequentially named files when defining an image sequence. I don’t think they look at the file date/time to determine order.
I am creating the files by taking snapshots in vMix, as stated in my original post.
Pinging the group again with the original question: Is there a shortcut value for a snapshot that will increment a file name in much the same way that "new file every" does in recording capture?
Alan, AFAIK it is not possible to add a sequence number field to file name templates in Snapshots, Recorder, etc. I thought I made a Feature Request for that years ago, but can't find it.
Joined: 2/26/2014(UTC) Posts: 83  Location: Canada Thanks: 18 times Was thanked: 16 time(s) in 16 post(s)
AlanZ If you code Python... or find a nice coder... you can probably get a script to capture your sequences as a timed delay if you do time-lapse.. and name your snapshots as you desire directly in Python... I got SnapshotInput working as a weblink... cool! For vMix 22!Stored in C:\Users\YourUser\Documents\vMixStorage http://localhost:8088/API/?Function=SnapshotInput&Input=1&Value=mysnapshot%20{0:yyyy-MM-dd%20H-mm-ss.f}.jpgAnd this little Python 2.7 script .... Code:import socket
import time
s = socket.socket(socket.AF_INET,socket.SOCK_STREAM)
s.connect(("localhost",8088))
sleeper = 1 #Time to wait in seconds between snapshots!
SnapshotInput = "GET /API/?Function=SnapshotInput&Input=1&Value=mysnapshot%20{0:yyyy-MM-dd%20H-mm-ss.f}.jpg HTTP/1.0\n\n"
def your_function1():
s.send(SnapshotInput)
#s.close()
while True:
your_function1()
time.sleep(sleeper)
I like a lot ReNamer snapshotRenamer.JPG (145kb) downloaded 1 time(s).
As I previously mentioned, I am not having any difficulty converting the capture images into a time-lapse file. I “simply” was looking for an alternative to the date/time naming convention (at create time, not via post processing) For anyone interested, here is my possibly unique use of vMix with an X-key controller to capture 3D print progress
Joined: 4/4/2016(UTC) Views messages in topic : 236  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
Just ran into this issue today. I wanted to use sequential names like many other image programs offer. So Image#####.png would give me a sequence starting Image00000.png Image00001.png Image00002.png. But I was only able to come up with a date time stamped version. What is that leading 0 in the name? Quote:0:yyyy-MM-dd H-mm-ss.f
I was thinking the 0 was for numbering except mine keep coming out with the same number to start. Since this is a test right now I wonder if later today it will change or if tomorrow it will be a different number.
Originally Posted by: RichShumaker  What is that leading 0 in the name? Quote:0:yyyy-MM-dd H-mm-ss.f
is part of the String.Format method in .net
Originally Posted by: doggy  Originally Posted by: RichShumaker  What is that leading 0 in the name? Quote:0:yyyy-MM-dd H-mm-ss.f
is part of the String.Format method in .net Honestly I have no idea I just copied from the example to make sure I didn't mess it up.
Joined: 4/23/2017(UTC) Posts: 1,475  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
Originally Posted by: daniel514  I like a lot ReNamer snapshotRenamer.JPG (145kb) downloaded 1 time(s). I use total commander for this task. It's a swiss army knife anyway.
