Hardware Compatibility
Behringer X-touch extender faders
Hi, we recently bought a Behringer X-touch extender. The shortcuts are working fine, but I cant get the fader activator work (motorized). Used the example in the manual, but this config doesnt work for me. Anyone have this working (even with other x-touches) and have some screenshots or config examples?
/Stian
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4739 time(s) in 1626 post(s)
Some things to try:
1. Make sure the device is enabled under Settings -> Activators -> Enable Devices 2. The faders on the X-Touch send a different MIDI note when touched vs when moved. You will need to make sure the correct settings are found when clicking Find after adding an activator. Make sure the values in Find are the ones that move up and down and moving the fader and you are not accidentally detecting the touch signal instead.
Martinv Mix
Hi, thank you for the reply. Im not sure how to find the correct note (or channel) for the motorized faders. Any quickfix? Secound question, is MC (Mackie-mode) the correct setup for the X-touch?
Joined: 12/29/2018(UTC) Posts: 10  Location: Siberia Was thanked: 1 time(s) in 1 post(s)
Hi, Stianeliassen. I have Behringer X-Touch One. It have only one fader, but I can use it in vMix. 1. First of all be shure, that you enable X-Touch in activator's devices (Enable Device button) 2. Change X-Touch mode to Control Change 3. Press Add button in Activators in vMix settings 4. Press Find Button in opened window 5. Slide X-Touch FADER to top or to bottom. Yoou can see that vMix show midi notes for this fader 6. In Event select Input Volume Channel Mixer (or MasterVolume for Master Volume) 7. In Type - Fader.
That's all.
Hi David, I also have an xtouch one, can you please assist in setting it up for vmix replay, via remote access, i tried to configure it, it wasn't detecting it for vmix
Hi, Damilare. Is your X-Touch device detected in Windows? Is it working in other programms, like Ableton Live or Adobe Audition?
Yes it detect on windows and also on vmix, could you please assist in setting it up for me via remote access any desk or teamviewer
Hi David, am still expecting your response
No, I can't assist you via remote access. What is the problem if it is detected in Windows and detected in vMix? Turn X-Touch mode to Control Change or Control Change Continuous, check the box "Behringer X-Touch" in MIDI Setting/MIDI Devices, Push ADD Button and push FIND. After press button on X-Touch or slide the fader.
Hi David is there any way you could assist in setting it up for vmix camera replay system, via image or video tutorial for set up, I Still can't figure it.. Kindly see the settings on my pc, with the link https://drive.google.com...TSVd69N3pYQy?usp=sharing my system detected it on device manager, likewise vmix...but not working
I have figure it now, it's working i check online for more tutorials about Midi activators..
