Increment Titler Value in Scripting
I would like to setup in Scripting a script that will read the current value of a field in an XAML, Increment that value by 1, then output the incremented value back to the XAML.
Basically I am trying to use my Stream Deck to increment the value in a field when someone scores a point. Once I know the basic syntax of incrementing I will be able to setup subtraction of points and resetting of points.
I did try to search for a similar topic but didn't find anything. I know that I can use UTC to do this as well as but I want to be able to use the Stream Deck with scripts.
Thank you in advance for a solution.
Originally Posted by: mediadisconnect  Basically I am trying to use my Stream Deck to increment the value in a field when someone scores a point.
+=1 to increase a value by one in aa xaml text field for streamdeck use a website api command http://localhost:8088/API/?Function=Settext......
doggy,
I have tried:
Function=SetText&Input=BasketBall.xaml&SelectedName=HomeScore&Value+=1 and Function=SetText&Input=BasketBall.xaml&SelectedName=HomeScore&Value=+1
but neither work. What am I missing?
Thanks.
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Try adding the extra "=" sign after value:
Function=SetText&Input=BasketBall.xaml&SelectedName=HomeScore&Value=+=1
The value must also be URLEncoded.
Thank you doggy. Your link showed me how to accomplish my goal in a script.
Thank you DWAM for showing me how to accomplish this in a Shortcut.
Originally Posted by: mediadisconnect  Thank you doggy. Your link showed me how to accomplish my goal in a script.
Thank you DWAM for showing me how to accomplish this in a Shortcut. And if you choose to use the Stream Deck either use the website configuration or the hotkey configuration if you have created a shortcut (mind you that with a shortcut vMix has to be the active window but that cab be fixed (open vMix)with the multi action option)
