mediadisconnect
#1 Posted : Tuesday, December 25, 2018 5:45:41 AM(UTC)
mediadisconnect
I would like to setup in Scripting a script that will read the current value of a field in an XAML, Increment that value by 1, then output the incremented value back to the XAML.
Basically I am trying to use my Stream Deck to increment the value in a field when someone scores a point. Once I know the basic syntax of incrementing I will be able to setup subtraction of points and resetting of points.
I did try to search for a similar topic but didn't find anything. I know that I can use UTC to do this as well as but I want to be able to use the Stream Deck with scripts.
Thank you in advance for a solution.
#2 Posted : Tuesday, December 25, 2018 6:12:42 AM(UTC)
+=1 to increase a value by one in aa xaml text field
for streamdeck use a website api command http://localhost:8088/API/?Function=Settext......
mediadisconnect
#3 Posted : Thursday, December 27, 2018 2:13:02 AM(UTC)
mediadisconnect
doggy,
I have tried:
Function=SetText&Input=BasketBall.xaml&SelectedName=HomeScore&Value+=1
and
Function=SetText&Input=BasketBall.xaml&SelectedName=HomeScore&Value=+1
but neither work. What am I missing?
Thanks.
#4 Posted : Thursday, December 27, 2018 3:18:13 AM(UTC)
raugert
#5 Posted : Thursday, December 27, 2018 3:39:57 AM(UTC)
raugert
Canada
Try adding the extra "=" sign after value:
Function=SetText&Input=BasketBall.xaml&SelectedName=HomeScore&Value=+=1
The value must also be URLEncoded.
#6 Posted : Thursday, December 27, 2018 3:45:57 AM(UTC)
mediadisconnect
#7 Posted : Thursday, December 27, 2018 3:53:53 AM(UTC)
mediadisconnect
Thank you doggy. Your link showed me how to accomplish my goal in a script.
Thank you DWAM for showing me how to accomplish this in a Shortcut.
#8 Posted : Thursday, December 27, 2018 4:02:08 AM(UTC)
And if you choose to use the Stream Deck either use the website configuration or the hotkey configuration if you have created a shortcut (mind you that with a shortcut vMix has to be the active window but that cab be fixed (open vMix)with the multi action option)
