attilio18
#1 Posted : Friday, December 21, 2018 2:10:23 AM(UTC)
attilio18
using TICKER HD I noticed that the text scrolling does not have a smooth speed but it flows in clicks, they are slight shots but I can see them ... I would like to know if someone, like me, has encountered the same problem and how he solved it ..
thanks a lot
#2 Posted : Friday, December 21, 2018 2:12:53 AM(UTC)
Please give details about your setup
GT or TD ?
Which GPU?
attilio18
#3 Posted : Friday, December 21, 2018 7:02:31 PM(UTC)
attilio18
Hi, the configuration of my pc is as follows:
cpu: intel core i7-7740x - 4.30 GHz
Nvidia Geforce GTX 1060 6GB
Blackmagic decklink quad2
Motherboard: Gigabyte Z370 AORUS
Thanks for the attention
Attilio
#4 Posted : Friday, December 21, 2018 8:51:54 PM(UTC)
are you using new GT or legacy Title Designer?
attilio18
#5 Posted : Friday, December 21, 2018 10:34:53 PM(UTC)
attilio18
Thanks for the quick reply, but I can not understand what you mean.
use vmix Title supplied with the program in ADD INPUT. In the Ticker section, I can choose 3 types of tickers.
and all 3 have the same problem .. when it flows the text is not fluid and snaps slightly .. but almost imperceptible
#6 Posted : Friday, December 21, 2018 11:14:06 PM(UTC)
That's precisely why I asked this question! New vMix 22 features a brand new Titler called GT (for Graphics Titler) which hugely improves fluidity/smoothness on tickers compared to legacy Title Designer.
Check it out!
attilio18
#7 Posted : Saturday, December 22, 2018 12:41:17 AM(UTC)
attilio18
Thank you so much, I installed version 22 and it seems that the ticker flows well, even if sometimes you notice a click in the ticker but it is imperceptible.
Since you've been so helpful for me, I'd like to take this opportunity to ask you something.
I have a remote control of the Newtek exactly the model LIVECONTROL LC-11. Is there a way to make it compatible with Vmix?
#8 Posted : Saturday, December 22, 2018 12:54:29 AM(UTC)
You'd better ask this new question in the appropriate category "Hardware Compatibility"
I think I remember someone already did it. Google it !
However I don't think such hardware control panels are appropriate for vMix 'cos they lack so much options to really take full advantage of all the unique features vMix has to offer...
I use an Akai APC Mini Controller which in my opinion is much better than the LC11 (for a fraction of the cost)
Check out the demo videos I did about it:
https://forums.vmix.com/...-Akai-APC-Mini-with-vMix
Guillaume
