Hello, using TICKER HD I noticed that the text scrolling does not have a smooth speed but it flows in clicks, they are slight shots but I can see them ... I would like to know if someone, like me, has encountered the same problem and how he solved it .. thanks a lot
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Please give details about your setup GT or TD ? Which GPU?
Hi, the configuration of my pc is as follows:
cpu: intel core i7-7740x - 4.30 GHz
Nvidia Geforce GTX 1060 6GB
Blackmagic decklink quad2
Motherboard: Gigabyte Z370 AORUS
Thanks for the attention Attilio
are you using new GT or legacy Title Designer?
Thanks for the quick reply, but I can not understand what you mean. use vmix Title supplied with the program in ADD INPUT. In the Ticker section, I can choose 3 types of tickers. and all 3 have the same problem .. when it flows the text is not fluid and snaps slightly .. but almost imperceptible
That's precisely why I asked this question! New vMix 22 features a brand new Titler called GT (for Graphics Titler) which hugely improves fluidity/smoothness on tickers compared to legacy Title Designer.
Check it out!
Thank you so much, I installed version 22 and it seems that the ticker flows well, even if sometimes you notice a click in the ticker but it is imperceptible. Since you've been so helpful for me, I'd like to take this opportunity to ask you something. I have a remote control of the Newtek exactly the model LIVECONTROL LC-11. Is there a way to make it compatible with Vmix?
You'd better ask this new question in the appropriate category "Hardware Compatibility" I think I remember someone already did it. Google it ! However I don't think such hardware control panels are appropriate for vMix 'cos they lack so much options to really take full advantage of all the unique features vMix has to offer... I use an Akai APC Mini Controller which in my opinion is much better than the LC11 (for a fraction of the cost) Check out the demo videos I did about it: https://forums.vmix.com/...-Akai-APC-Mini-with-vMixGuillaume
