i.yaropolov
#1 Posted : Thursday, December 20, 2018 4:25:23 PM(UTC)
i.yaropolov
Russian Federation
Difficult to explain:(
Possibility to have 1 camera with 4K resolution as input and 4-5 adjustable on the fly shots.
Below is href to feature in LS
https://help.livestream....ed-Input-Source-Cropping
Vuurmannetje
#2 Posted : Thursday, December 20, 2018 5:10:55 PM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
This is already possible to achieve now and even easier in the upcoming Version 22
Currently:
1 Create a virtual input of your 4k source for each camera you want to set up.
2 Crop each source as you want your camera to fit
Future:
Each input will have virtual PTZ control allowing you to set up your cameras. Again, use multiple virtual inputs of your source if you want them as separate inputs
i.yaropolov
#3 Posted : Thursday, December 20, 2018 6:05:27 PM(UTC)
i.yaropolov
Russian Federation
Please, check 4K crop in LS. It's free. The main advantage of LS is possibility to adjust each crop size and postion in 4K frame. It is important.
I can create any number of virtual inputs and adjust each input accordingly. But I have not possibility to adjust crop on 4K frame on the fly - this is important:)
Vuurmannetje
#4 Posted : Thursday, December 20, 2018 6:37:03 PM(UTC)
Vuurmannetje
Try out the Vmix 22 beta, its virtual PTZ is exactly what you want I think.
