	Feature Requests
	4K Crop as in Livestream Studio
 Joined: 12/20/2018(UTC) Posts: 3  Location: Moscow, Russia
 Joined: 5/14/2018(UTC) Posts: 114 Location: Netherlands
  Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
                This is already possible to achieve now and even easier in the upcoming  Version 22
  Currently: 1 Create a virtual input of your 4k source for each camera you want to set up. 2 Crop each source as you want your camera to fit
  Future: Each input will have virtual PTZ control allowing you to set up your cameras. Again, use multiple virtual inputs of your source if you want them as separate inputs
                Please, check 4K crop in LS. It's free. The main advantage of LS is possibility to adjust each crop size and postion in 4K frame. It is important. I can create any number of virtual inputs and adjust each input accordingly. But I have not possibility to adjust crop on 4K frame on the fly - this is important:)
                Try out the Vmix 22 beta, its virtual PTZ is exactly what you want I think.
	Feature Requests
