Joined: 12/5/2018(UTC) Posts: 5  Location: Mattoon Thanks: 1 times
I am at a small college that has VB/Basketball/Baseball and am trying to find either usable scoreboards for Baseball/Softball or an easy way to make a scoreboard. I tried the way they explain in on VMix but cannot seem to get it to work. I am able to use the basketball scoreboards fine and was able to add a text box to them to get what I wanted.
For baseball/softball just looking for a scoreboard where I could do inning by inning as well as hits/errors and maybe LOB. Honestly I am not very good at designing. Baseball would have 7 inn or 9 inn usually and softball 7 innings.
Any help or advice is appreciated.
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
Originally Posted by: bcolvin1978  I am at a small college that has VB/Basketball/Baseball and am trying to find either usable scoreboards for Baseball/Softball or an easy way to make a scoreboard. I tried the way they explain in on VMix but cannot seem to get it to work. I am able to use the basketball scoreboards fine and was able to add a text box to them to get what I wanted.
Any help or advice is appreciated. Try this https://www.live-score-app.com/baseball
Reading their site if I buy the standard addition 39 EUR it will say demo on the screen, is this correct? We are not a huge budget school. I wouldn't mind getting the baseball and basketball both but am curious to how easy it is to get VMix on my laptop to see it during the broadcast and how hard to update it actually is.
Go with Siroki's suggestion. 39 Euros is approximately $44.27 US.
I've used their scoreboard for softball. It has an NDI option. I run the software on a old laptop and bring in the scoreboard with the NDI option to my main vMix system.
Originally Posted by: SportsNetUSA.net  Go with Siroki's suggestion. 39 Euros is approximately $44.27 US.
I've used their scoreboard for softball. It has an NDI option. I run the software on a old laptop and bring in the scoreboard with the NDI option to my main vMix system. So do you download to your desktop and then use the phone to increase/decrease score/fouls and such? And does the $44 version say anything about demo on it?
Thanks I will look at doing the trial our next home game (January).
The vmix title editor makes it easy to customize scoreboards. Make or find a baseball scoreboard image: http://www.planet-baseba...l-scoreboard-9-blank.pngLoad in vmix title and add the scores as text fields. https://drive.google.com...sUoqhpzFyAYD?usp=sharingHere is one that I made that has score and base indicators. It also has the images in the folder- I share it here so you can see how the bases are indicated with images and then activated by shortcut. Here is what the shortcuts look like. https://snag.gy/qftUKA.jpgThis brings base "On". To take the base off, create another with a blank filename. Bottom line -- photoshop and vmix title are all you need IMO. Im here to help if needed. If you give me sense of what you are looking for I can get you started in PSD.
 2 users thanked kjones9999 for this useful post.
@kjones9999
Nice stuff you put together for a baseball/softball scoreboard. Certainly would get the job done.
 1 user thanked SportsNetUSA.net for this useful post.
Wow that is impressive. I am just starting to play with the editor stuff. Tried to follow the instructions I found on using paint or another editor but couldn't get it to work right. I have been able to take their existing basketball scoreboards and add text boxes for quarter/half. I wish VMix had included at least one scoreboard template for each major sport here (Baseball/Softball, Volleyball)
Originally Posted by: kjones9999  The vmix title editor makes it easy to customize scoreboards. Make or find a baseball scoreboard image: http://www.planet-baseba...l-scoreboard-9-blank.pngLoad in vmix title and add the scores as text fields. https://drive.google.com...sUoqhpzFyAYD?usp=sharingHere is one that I made that has score and base indicators. It also has the images in the folder- I share it here so you can see how the bases are indicated with images and then activated by shortcut. Here is what the shortcuts look like. https://snag.gy/qftUKA.jpgThis brings base "On". To take the base off, create another with a blank filename. Bottom line -- photoshop and vmix title are all you need IMO. Im here to help if needed. If you give me sense of what you are looking for I can get you started in PSD. Just now finding this, how do you get the base to toggle while having it on the same graphic? I could never get it figured out. I have been just creating all of my bases and outs as separate graphics and using the multiview function.
