kevinrhaggerty
#1 Posted : Thursday, December 6, 2018 9:43:50 AM(UTC)
kevinrhaggerty
I'm a new user. Using vMix on a laptop running Windows 10 with specs that meet the requirements.
I'm using a Yuan PD570 Pro HDMI capture device, and running a Canon XA10 for video. For audio, I'm running the outputs from the sound board via XLR cables into a PreSonus AudioBox USB for the audio.
It isn't clipping, and there's no pop in the house speakers, but in the Facebook live stream, the audio keeps clicking/popping.
Help?
SportsNetUSA.net
#2 Posted : Thursday, December 6, 2018 10:11:52 AM(UTC)
SportsNetUSA.net
What about when you monitor with headphones directly out of the PreSonus?
Does your laptop have both USB 3.0/3.1 and USB 2.0? If so, what happens if you plug the PreSonus into a USB 2.0 port?
kevinrhaggerty
#3 Posted : Thursday, December 6, 2018 10:24:39 AM(UTC)
kevinrhaggerty
Yes, I do have both. Honestly, I feel a little silly bc I didn't even think to try one of the 2.0 ports. Will try that and report back. Thanks for the suggestion!
Barney Box Lane
#4 Posted : Thursday, December 6, 2018 8:27:14 PM(UTC)
Barney Box Lane
You might need a buffer somewhere.. we had the same from camera to computer, video with audio takes a bit more encoding (i thought it was strange the video could get through cleanly but the audio struggled but thats why)
#5 Posted : Thursday, December 6, 2018 9:53:44 PM(UTC)
Check your ASIO drivers and ASIO buffers. When set too low (lower latency), clicks and pops are prone to happen.
Guillaume
kevinrhaggerty
#6 Posted : Friday, December 7, 2018 3:45:53 AM(UTC)
kevinrhaggerty
Sorry for my ignorance, but I'm super new to all this. When you say "add a buffer," what exactly do you mean?
Is this a setting I would change in vMix or somewhere else?
Thanks!
mavik
#7 Posted : Tuesday, December 11, 2018 2:04:57 AM(UTC)
mavik
Was thanked: 185 time(s) in 165 post(s)
As Guillaume said. It's the ASIO driver that you need to adjust. Nothing in vMix.
Barney Box Lane
#8 Posted : Tuesday, December 11, 2018 10:00:31 PM(UTC)
Barney Box Lane
Forgiven! it's just the delay you want to add in the settings of your camera inputs that are popping, you add it in milliseconds 1000 = 1 sec
