HamishBode
#1 Posted : Monday, December 3, 2018 7:22:41 PM(UTC)
HamishBode
Hi vmixers! I'm running into a specific issue and maybe there's simple solution I just haven't thought of yet.
On our set, we have a TV in the background that I am controlling via Vmix on External Output 2. I am able to change the input going to this External Output by creating a shortcut which "works" but isn't exactly the solution I was hoping for. There isn't a way to adjust this transition from what I can see but I would love to fade between the inputs going to External Output 2. Is there a solution for this that exists in Vmix?
Cheers in advance.
#2 Posted : Tuesday, December 4, 2018 12:39:00 PM(UTC)
@ HamishBode
Unfortunately, External Output 2 is only configurable "to be" or "not to be" and there is no way to apply a transition if wanting to change its source Input, it is basically just a hard cut.
HamishBode
#3 Posted : Tuesday, December 4, 2018 9:10:37 PM(UTC)
HamishBode
@IceStream - thanks for the reply!
I think I'll put in a feature request to see if a duration field can be added to the SelectExternalOutput function.
Beyond that, can you think of any creative way to have an input be sent to External Output 2 that would be able to receive a set of inputs that could be faded between? It may not be possible or maybe I'm missing and extremely obvious solution!
#4 Posted : Wednesday, December 5, 2018 2:04:19 AM(UTC)
Use NDI to feed a 2nd vMix (or OBS) with your inputs
HamishBode
#5 Posted : Wednesday, December 5, 2018 2:26:13 AM(UTC)
HamishBode
That's what I was thinking too. Could probably put a laptop aside for this. Appreciate the input @DWAM!
mavik
#6 Posted : Wednesday, December 5, 2018 4:39:29 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
Maybe another creative way would be to set the output 2 to a fixed input. On the input use a multiview and the alpha to fade from one layer to the other. Short HowTo
1. create virtual input for the both shots. Lets assume they are #3 and #4
2. Create a blank input (#5) go to multiview and set #3 and #4 in layer 1 and 2 respectively.
3. Set the output #2 to show input #5 (the multiview you just created)
4. Now changing alpha of input #4 will fade it and you will see input #3 on output #2. You can link a midi fader or whatever in the shortcuts to control the alpha.
Hope that helps.
HamishBode
#7 Posted : Wednesday, December 5, 2018 7:01:11 PM(UTC)
HamishBode
@mavik I like the way you think! Will give that a go and let you know how I get on. Thanks :D
