Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
Hi have a desktop capture that is not saving its size settings. The desktop is being captured at 1600x900. When I went into the size option, one of them was .996. So I changed them all to a value of 1. This fixed the problem. However, when I close vMix and then open it back up, the size goes back to .996. No matter how many times I save the preset file, it always goes back to .996 resulting in a sliver of black on the left as shown in the video below at about 0:07. Any ideas?
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
This is by design, if the aspect ratio does not exactly match 16:9 so vMix will add black bars to keep everything proportional.
That said, if you change the option to .9999 it should save in the preset, but 1 signals vMix to correct the aspect ratio automatically.
Martin vMix
Great to know thankyou!!
One Question, how does 1600x900 not fit into 16:9? Its perfectly divisible by itself.
You're right, it should match the aspect ratio exactly. Is the size in Input Settings listed as 1600x900?
I just did a test at 1600x900 and no black bars were added (and also in the preset).
Martin vMix
Yes it is. That is the weird thing. When everything is at a the normal setting, ie "1"'s in all the size settings, the image looks correct. However, its only when I shut down vMix and load it up again that it happens.
Could you email me the preset so I can take a look? (Email address is on our web site)
My error, the resolution was actually 1366x768.
Somehow it was set at 1360x768. So I reloaded it to the correct 1366x768. However now when I open the preset the "Zoom Y" automatically reloads as 0.9995. Same issue. I reset it to 1 and everything is great. When I open it up, it changes back to .9995
