Api commands: discontinuity in volume levels
Thanks: 2 times Was thanked: 10 time(s) in 9 post(s)
I´m currently facing a problem regarding volume parameters using the api. I´m building a controller that has a volume control. So I´m trying to read the current volume from the api and then increase or decrease that value when my encoder is turned. If the volume is set to 75% (-3dB) in vMix, and I read that value from the api it will return the value 75. However, when I now for example increase that value by +1 and write back 76 to the api the value afterwards will be 32% (-10dB). So for some reason there is a different scale for reading and writing the volume levels. Is that intended? How can I perform a calculation from one value to the other?
The commands I´m using are: "ACTS InputVolume 1" for reading the current volume, however it´s the same value when I use "XMLTEXT vmix/inputs/input[1]/@volume" and "FUNCTION SetVolume Value=75&Input=1" for writing the new volume level.
Hope someone can help me here.
Regards Yannick
Joined: 8/5/2017(UTC) Posts: 582  Location: Manitoba Thanks: 121 times Was thanked: 322 time(s) in 184 post(s)
