Yannick
#1 Posted : Wednesday, November 28, 2018 2:57:22 AM(UTC)
Yannick
I´m currently facing a problem regarding volume parameters using the api.
I´m building a controller that has a volume control.
So I´m trying to read the current volume from the api and then increase or decrease that value when my encoder is turned.
If the volume is set to 75% (-3dB) in vMix, and I read that value from the api it will return the value 75.
However, when I now for example increase that value by +1 and write back 76 to the api the value afterwards will be 32% (-10dB).
So for some reason there is a different scale for reading and writing the volume levels.
Is that intended? How can I perform a calculation from one value to the other?
The commands I´m using are:
"ACTS InputVolume 1" for reading the current volume, however it´s the same value when I use "XMLTEXT vmix/inputs/input[1]/@volume" and
"FUNCTION SetVolume Value=75&Input=1" for writing the new volume level.
Hope someone can help me here.
Regards
Yannick
raugert
#2 Posted : Thursday, November 29, 2018 10:25:47 AM(UTC)
raugert
Canada
The volume level returned from the API is not linear. This article should help you with the formula.
https://www.vmix.com/kno...44/vmix-api-audio-levels
