Feature Requests
Master alpha / dimmer fader for output
It would be nice to have a master dimmer fader to set the output (alpha) for every input. Sometimes I use projectors which are to bright and I need to adjust the alpha (dimmer).
Now I need to adjust it on every single input.
Rank:: Advanced Member
Assuming you are sending your Output to the Projector (which btw normally has a setting for decreasing the light) there is a workaround. 1. In Settings/Output set NDI On for Output 2. Add a new NDI Input with your Output as its source 3. Set the Desired alpha level in that Input 4. Set Fullscreen to that Input Of course, this workaraound via NDI would not be necessary if the Feature Request Use the Output (aka Active) as a source for Inputs was implemented ;)
Feature Requests
