Raju
#1 Posted : Tuesday, November 20, 2018 7:12:39 PM(UTC)
Raju
Nigeria
Hello I want to find out if tie camera.
https://www.amazon.com/A...Conference/dp/B017JMS59O
Will be compatible and cnfigurable with vmix and will be able to do all control and features of the camera within
mjgraves
#2 Posted : Wednesday, November 21, 2018 1:38:55 AM(UTC)
mjgraves
I've reviewed a similar model from the manufacturer. Itw as the all-in-one conference system with a speakerphone.
https://www.mgraves.org/...onference-camera-system/
The model you reference is just the camera. It has RS232 serial PTZ control using Sony's VISCA protocol. If you use this you should have complete PTZ control from vMix Pro or 4K.
I'm not sure if PTZ control via USB alone is full-featured.
Raju on 11/22/2018(UTC)
Raju
#3 Posted : Thursday, November 22, 2018 3:10:06 AM(UTC)
Raju
Nigeria
Thanks; So you are suggesting connection should be through the RS232 serial PTZ using the sony visca protocol?
mjgraves
#4 Posted : Thursday, November 22, 2018 3:20:49 AM(UTC)
mjgraves
The video is passed to the host via USB.
There's also a DIN style RS232 connector that allows VISCA control.
It's shown clearly in the data sheet. http://www.averusa.com/v...ads/cam520-datasheet.pdf
The DIN-to-DB9 cable for VISCA control is optional.
You can also use their app for PTZ remote control from the host PC. That will give you full PTZ control
