Joined: 11/20/2018(UTC) Posts: 2  Location: Lagos Thanks: 3 times
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
I've reviewed a similar model from the manufacturer. Itw as the all-in-one conference system with a speakerphone. https://www.mgraves.org/...onference-camera-system/The model you reference is just the camera. It has RS232 serial PTZ control using Sony's VISCA protocol. If you use this you should have complete PTZ control from vMix Pro or 4K. I'm not sure if PTZ control via USB alone is full-featured.
Thanks; So you are suggesting connection should be through the RS232 serial PTZ using the sony visca protocol?
Originally Posted by: Raju  Thanks; So you are suggesting connection should be through the RS232 serial PTZ using the sony visca protocol? The video is passed to the host via USB. There's also a DIN style RS232 connector that allows VISCA control. It's shown clearly in the data sheet. http://www.averusa.com/v...ads/cam520-datasheet.pdfThe DIN-to-DB9 cable for VISCA control is optional. You can also use their app for PTZ remote control from the host PC. That will give you full PTZ control
