spencerm24
#1 Posted : Wednesday, November 21, 2018 12:37:38 AM(UTC)
spencerm24
I'm trying to make a record file, as MXF, Anyone know of a way to get vMix to record to MXF XDCAM 4:2:2? This is for use in another facility where they require this format for all recordings.
thanks 1 user thanked spencerm24 for this useful post.
PFBM on 11/22/2018(UTC)
spencerm24
#2 Posted : Wednesday, November 21, 2018 1:02:18 AM(UTC)
spencerm24
Ok so I had a dumb moment, I found MXF, however, in "quality" I know what the usual stuff is such as 1080 59.94i 29.97p but there are numbers before it I have no idea what they mean "145 1080 59.94i, 29.97p" What does the leading 145 mean?
Also, when I tried to record, I am given an error a second or two after starting saying the recording stopped unexpectedly. Any ideas on how I can solve this?
#3 Posted : Wednesday, November 21, 2018 1:33:41 AM(UTC)
MXF is a professional container for broadcast standards. So don't expect it to be "plug and play" or "click and see what happens, I might get lucky"... It's all about compliance and specs, it's not up to you to decide what you can do or not. You must conform to the specs.
Check documentation about MXF format
https://tech.ebu.ch/docs...view/trev_291-devlin.pdf
http://avid.force.com/pk...S/Compatibility/en336555
https://en.wikipedia.org...Material_Exchange_Format
And remember that MXF is a "container" that accepts various codecs to be (strictly) used at certain conditions.
145 is a bitrate in Mbits
Guillaume
spencerm24
#4 Posted : Wednesday, November 21, 2018 1:41:28 AM(UTC)
spencerm24
Guillaume
I'm aware of that, its a format that is broadcast standard. I have been asked to use the MXF container with XDCAM 4:2:2 codec at 50mbps. I'm not trying to "hope I get lucky" I'm trying to get vMix to output a format that is of the broadcast standard that is fairly common.
#5 Posted : Wednesday, November 21, 2018 2:11:14 AM(UTC)
which vMix does not support by default. Only option in vMix (by default) is MXF with DNxHD which has nothing in common with XDCAM
spencerm24
#6 Posted : Wednesday, November 21, 2018 4:46:13 AM(UTC)
spencerm24
Not possible. got it.
Well that sucks, was hoping to use vMix for this workflow which requires this for many hundreds of videos produced, but that doesn't seem possible now without transcoding.
#7 Posted : Wednesday, November 21, 2018 4:54:12 AM(UTC)
I said it's not possible "by default" internally but vMix has everything you need to feed an MXF recorder
spencerm24
#8 Posted : Wednesday, November 21, 2018 5:32:37 AM(UTC)
spencerm24
I was hoping for a turnkey default solution, rather than spend time configuring and figuring out how to feed an external MXF recorder. Sure anything is possible with outputs, but it requires time, effort, software, configuring. I'll just use another production method that can generate MXF.
PFBM
#9 Posted : Thursday, November 22, 2018 12:35:39 AM(UTC)
PFBM
SIENNA TV
NDI Processing Engine MXF Recorders, Players, MeterBridge
http://www.sienna-tv.com/ndi/ndiprocessor.html
i wish..... vMix had that kind of XDCAMHD 50 MXF recorder...... :)
thanks 1 user thanked PFBM for this useful post.
ask on 11/22/2018(UTC)
mavik
#10 Posted : Friday, November 23, 2018 2:36:03 AM(UTC)
mavik
Withthe next version vMix will have better recording capabilities. But they will use more or less a propriatary codec for that if I understood the announcement correct.
PFBM
#11 Posted : Friday, November 23, 2018 8:55:14 PM(UTC)
PFBM
yes , i dont agree with it .... not for all editing software.... not a standard....
vMIx should have a XDCAM HD 50 MXF recording capability.... because is a broadcast standard....
also just like AVC Intra 100 MXF
https://www.digitalproductionpartnership.co.uk
https://www.amwa.tv/projects/AS-11.shtml
this is a Broadcast Info Standard , Please Martin... have a look.
Cheers,
PFBM
