sinc747
#1 Posted : Friday, November 9, 2018 9:18:36 AM(UTC)
sinc747
Was thanked: 205 time(s) in 171 post(s)
I have a 4K camera as an input in vMix. Resolution is 3840x2160. In the camera input I go to Settings -> Position -> Zoom. Instead of using the zoom slider, I set the zoom to 3. What resolution do I now have? 1080? 720?
Asking for 100 friends. ;)
- Tom
madness
#2 Posted : Friday, November 9, 2018 11:30:01 PM(UTC)
madness
Do a still image capture and open it up in paint should tell you.
sinc747
#3 Posted : Saturday, November 10, 2018 6:28:41 AM(UTC)
sinc747
Thanks you and Thank you!
mjgraves
#4 Posted : Tuesday, November 20, 2018 2:53:40 AM(UTC)
mjgraves
I did a little experiment. In Photoshop I created a 4K sample image. Then I overlaid reference 1080p and 720p images.
In vMix, with zoom = 1.0 the entire 4K image is visible full screen.
When zoom = 2.0 the 1080p size portion image is visible full screen.
When zoom = 3.0 the 720p size portion image is visible full screen.
