What resolution do I get when I zoom a 4K video to 3?
Joined: 8/2/2013(UTC) Posts: 1,111   Location: Fairhope, Alabama USA Thanks: 604 times Was thanked: 205 time(s) in 171 post(s)
I have a 4K camera as an input in vMix. Resolution is 3840x2160. In the camera input I go to Settings -> Position -> Zoom. Instead of using the zoom slider, I set the zoom to 3. What resolution do I now have? 1080? 720? Asking for 100 friends. ;) - Tom  Capture.JPG (39kb) downloaded 2 time(s).
Do a still image capture and open it up in paint should tell you.
Thanks you and Thank you!
I did a little experiment. In Photoshop I created a 4K sample image. Then I overlaid reference 1080p and 720p images. In vMix, with zoom = 1.0 the entire 4K image is visible full screen. When zoom = 2.0 the 1080p size portion image is visible full screen. When zoom = 3.0 the 720p size portion image is visible full screen.
