docktalk
#1 Posted : Thursday, November 15, 2018 3:05:08 PM(UTC)
docktalk
Has anyone used the Kona Hdmi capture card in an external TB3 enclosure yet? any pros / cons / advice
I am very new to this streaming game and am trying to run a simple, well what I perceive
a simple set-up and am failing.
I have tried two U-Taps and vMix does not like that / or my laptop does not, they keep getting
kicked off / disconnected. After some discussion it seems my laptop usb 3.0 can not handle the
U-Taps, hell even when I run 1 it gets kicked off.
So the new plan is to run the Kona Hdmi capture card, in a TB3 external enclosure, into laptop Helios 500
Vmix software and that should in my understanding enable multi camera live streaming and very few hiccups.
any advice would be appreciated, I feel like I'm spinning down a rabbit hole
zenvideo
#2 Posted : Friday, November 16, 2018 4:00:19 AM(UTC)
zenvideo
I've not used the Kona card but I have used an external Zotac TB3 box with another Quad HDMI card and the performance appeared to be the same as having the card installed in a PCIe slot on a desktop motherboard. Plus this particular TB3 box has a USB3 host controller+ports as well, so I tried running a USB3 capture device alongside the quad card. I didn't do a multi-hour "soak test", so I can't confirm long-form stability, but as far as it went I was getting clean video simultaneously from both types of source. YMMV with your specific computer.
SportsNetUSA.net on 11/16/2018(UTC)
docktalk
#3 Posted : Friday, November 16, 2018 4:19:51 AM(UTC)
docktalk
Great reviews on that "box" - would my assumptions be correct in that kona had not released yet so magewell was the choice? - any issues with that card? it is on the maybe list - Thanks for the reply
zenvideo
#4 Posted : Friday, November 16, 2018 5:13:33 AM(UTC)
zenvideo
The simple answer is that I'm a Magewell reseller so have a variety of their products to hand.
docktalk
#5 Posted : Friday, November 16, 2018 5:20:02 AM(UTC)
docktalk
Understood - So I have to down to, two enclosures and 2 capture cards ....
SportsNetUSA.net
#6 Posted : Friday, November 16, 2018 9:52:20 AM(UTC)
SportsNetUSA.net
I've used a Kona 3G with a Sonnet Echo Express Thunderbolt 2 enclosure. Everything worked well and as expected (until the Win 1083 update, then everything got buggy). Also have used a Magewell Pro Capture Quad with a Sonnet Thunderbolt 3 enclosure. No issues.
Depending on your laptop there shouldn't be an issue with a Kona 3G and a TB3 enclosure.
hellokitty
#7 Posted : Sunday, November 18, 2018 5:43:20 PM(UTC)
hellokitty
I use this with a Kona 4, no problems. http://www.sonnettech.co...t/echoexpressse1tb3.html
docktalk
#8 Posted : Monday, November 19, 2018 12:20:28 AM(UTC)
docktalk
Noise factor? have read this brand is noisey
SportsNetUSA.net
#9 Posted : Tuesday, November 20, 2018 3:37:39 AM(UTC)
SportsNetUSA.net
I never noticed that. Just plugged mine in, it's quiet. Now if the capture card has a fan that is noisy, that will be a problem.
The two Sonnet Echo boxes I've worked with haven't had any noise issues.
Guest (5)
