Questions concerning the TCP API
So I've used the Web API, but was unaware of the TCP API until this week. I'm attempting to use it, but am confused! What are you sending the commands with? A browser? script code? In a browser, all I get is a search response. It's obvious I am misinterpreting the information provided. I had been using Autohotkey to send commands via web commands to vMix, but if the TCP API is more efficient, its obviously the way to go. Just need a little push in the right direction to get started.
Can anyone give me a push?
Joined: 8/4/2015(UTC) Posts: 17   Thanks: 5 times Was thanked: 8 time(s) in 4 post(s)
First you need to connect to vMix using TCP protocol. Then transmit the command in UTF-8 format. Also check the answer from the sent command success or error.
So what are you using to transmit/connect?
TCP connection example
client.Connect("127.0.0.1", 8099); NetworkStream stream = client.GetStream(); Byte[] readingData = new Byte[1024]; String responseData = String.Empty; StringBuilder completeMessage = new StringBuilder(); int numberOfBytesRead = 0; do { numberOfBytesRead = stream.Read(readingData, 0, readingData.Length); completeMessage.AppendFormat("Answer: {0}", Encoding.UTF8.GetString(readingData, 0, numberOfBytesRead)); } while (stream.DataAvailable); responseData = completeMessage.ToString(); textBox1.Text = responseData;
Example of TCP transfer vMix command
textBox1.Text = ""; Byte[] data = Encoding.UTF8.GetBytes("FUNCTION OverlayInput1Out\r\n"); NetworkStream stream = client.GetStream(); stream.Write(data, 0, data.Length); Byte[] readingData = new Byte[1024]; String responseData = String.Empty; StringBuilder completeMessage = new StringBuilder(); int numberOfBytesRead = 0; do { numberOfBytesRead = stream.Read(readingData, 0, readingData.Length); completeMessage.AppendFormat("Answer: {0}", Encoding.UTF8.GetString(readingData, 0, numberOfBytesRead)); } while (stream.DataAvailable); responseData = completeMessage.ToString(); textBox1.Text = responseData;
 3 users thanked Stealth77 for this useful post.
Joined: 7/6/2021(UTC) Posts: 22   Location: Münster Thanks: 4 times
Could anybody explain me how to use this example, please. I tried to put it in Visual Studio 2022 to make a consoleaplication in C++ and in C# without success. Or could somebody translate this in Visual Basic. From the user guide I took: Example Request: FUNCTION PreviewInput Input=5\r\n and changed it to FUNCTION Play Input 1\r\n In Visual Basic I try Code:Imports System.Net.Sockets
Imports System.IO
Module Module1
Dim stream As NetworkStream
Dim streamw As StreamWriter
Dim streamr As StreamReader
Dim client As New TcpClient
Dim strBefehl As String
Sub Main()
strBefehl = "FUNCTION Play Input 1\r\n"
Try
If client.Connected Then
streamw = New StreamWriter(stream)
streamr = New StreamReader(stream)
streamw.WriteLine(encode(strBefehl))
Console.WriteLine(encode(strBefehl))
Console.WriteLine(strBefehl)
streamw.Flush()
Console.WriteLine(Receive)
client.Close()
stream.Close()
streamw.Close()
streamr.Close()
Else
Console.WriteLine("Not connected")
End If
Catch
Console.WriteLine("gar nicht connected")
End Try
End Sub
Function Receive() As String
Try
Return streamr.ReadLine
Catch
Return ""
End Try
End Function
Function encode(ByVal str As String) As String
'supply True as the construction parameter to indicate
'that you wanted the class to emit BOM (Byte Order Mark)
'NOTE: this BOM value is the indicator of a UTF-8 string
Dim utf8Encoding As New System.Text.UTF8Encoding(True)
Dim encodedString() As Byte
encodedString = utf8Encoding.GetBytes(str)
Return utf8Encoding.GetString(encodedString)
End Function
End Module
and I got an answer from vMix: FUNCTION Play Input 1\r\n FUNCTION Play Input 1\r\n VERSION OK 26.0.0.40 but the video in 1 did not start Thank you Martin
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Originally Posted by: MDB  From the user guide I took: Example Request: FUNCTION PreviewInput Input=5\r\n and changed it to FUNCTION Play Input 1\r\n
Shouldn't it be "FUNCTION Play Input=1\r\n" then?
Oh yes, you are right (it was too late) I will give it a try
Thank you
I tried "FUNCTION Play Input=1\r\n" and "FUNCTION=Play Input=1\r\n" and also "FUNCTION PreviewInput Input=1\r\n" without success (http://http://127.0.0.1:8088/API/?Function=Play&Input=1 works)
Shows this line "VERSION OK 26.0.0.40" that a connection to VMix was established?
Finally I succeded to start the video in input 1 with: strBefehl = "FUNCTION Play Input=1" & vbCrLf
