madness
#1 Posted : Sunday, November 11, 2018 9:26:13 AM(UTC)
madness
So I've used the Web API, but was unaware of the TCP API until this week. I'm attempting to use it, but am confused!
What are you sending the commands with? A browser? script code? In a browser, all I get is a search response. It's obvious I am misinterpreting the information provided. I had been using Autohotkey to send commands via web commands to vMix, but if the TCP API is more efficient, its obviously the way to go. Just need a little push in the right direction to get started.
Can anyone give me a push?
Stealth77
#2 Posted : Tuesday, November 13, 2018 1:40:02 AM(UTC)
Stealth77
Russian Federation
Was thanked: 8 time(s) in 4 post(s)
First you need to connect to vMix using TCP protocol.
Then transmit the command in UTF-8 format.
Also check the answer from the sent command success or error.
madness
#3 Posted : Tuesday, November 13, 2018 12:02:53 PM(UTC)
madness
So what are you using to transmit/connect?
Stealth77
#4 Posted : Wednesday, November 14, 2018 6:28:54 AM(UTC)
Stealth77
Russian Federation
TCP connection example
Example of TCP transfer vMix command
thanks 3 users thanked Stealth77 for this useful post.
madness on 11/14/2018(UTC), Pro321Video on 12/30/2020(UTC), qa_p1981 on 3/22/2023(UTC)
MDB
#5 Posted : Monday, March 27, 2023 4:40:54 AM(UTC)
MDB
Germany
Could anybody explain me how to use this example, please. I tried to put it in Visual Studio 2022 to make a consoleaplication in C++ and in C# without success.
Or could somebody translate this in Visual Basic.
From the user guide I took: Example Request: FUNCTION PreviewInput Input=5\r\n
and changed it to FUNCTION Play Input 1\r\n
In Visual Basic I try
Code:
Imports System.Net.Sockets
Imports System.IO
Module Module1
    Dim stream As NetworkStream
    Dim streamw As StreamWriter
    Dim streamr As StreamReader
    Dim client As New TcpClient
    Dim strBefehl As String
    Sub Main()
        strBefehl = "FUNCTION Play Input 1\r\n"
        Try
            client.Connect("127.0.0.1", 8099)
            If client.Connected Then
                stream = client.GetStream
                streamw = New StreamWriter(stream)
                streamr = New StreamReader(stream)
                streamw.WriteLine(encode(strBefehl))
                Console.WriteLine(encode(strBefehl))
                Console.WriteLine(strBefehl)
                streamw.Flush()
                Console.WriteLine(Receive)
                client.Close()
                stream.Close()
                streamw.Close()
                streamr.Close()
            Else
                Console.WriteLine("Not connected")
            End If
        Catch
            Console.WriteLine("gar nicht connected")
        End Try
    End Sub
    Function Receive() As String
        Try
            Return streamr.ReadLine
        Catch
            Return ""
        End Try
    End Function
    Function encode(ByVal str As String) As String
        'supply True as the construction parameter to indicate
        'that you wanted the class to emit BOM (Byte Order Mark)
        'NOTE: this BOM value is the indicator of a UTF-8 string
        Dim utf8Encoding As New System.Text.UTF8Encoding(True)
        Dim encodedString() As Byte
        encodedString = utf8Encoding.GetBytes(str)
        Return utf8Encoding.GetString(encodedString)
    End Function
End Module
and I got an answer from vMix:
VERSION OK 26.0.0.40
but the video in 1 did not start
Thank you
dmwkr
#6 Posted : Monday, March 27, 2023 6:09:05 PM(UTC)
dmwkr
Shouldn't it be "FUNCTION Play Input=1\r\n" then?
MDB
#7 Posted : Monday, March 27, 2023 8:19:26 PM(UTC)
MDB
Germany
Oh yes, you are right (it was too late)
I will give it a try
Thank you
MDB
#8 Posted : Tuesday, March 28, 2023 6:39:51 PM(UTC)
MDB
Germany
I tried "FUNCTION Play Input=1\r\n"
and "FUNCTION=Play Input=1\r\n"
and also "FUNCTION PreviewInput Input=1\r\n"
without success
(http://http://127.0.0.1:8088/API/?Function=Play&Input=1 works)
Shows this line "VERSION OK 26.0.0.40" that a connection to VMix was established?
MDB
#9 Posted : Tuesday, March 28, 2023 7:24:02 PM(UTC)
MDB
Germany
Finally I succeded to start the video in input 1 with:
strBefehl = "FUNCTION Play Input=1" & vbCrLf
Guest (7)
