stevespaw
#1 Posted : Tuesday, November 6, 2018 3:35:42 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
I thought for sure I had done this before, but now I cannot find out how to do this.
I need to create a Loadable Template for a custom keyboard and another project a custom Midi controller.
I have a PNG images of the devices, I have created shortcuts. How can I create a template for them? And save for distribution. Is this possible?
Thanks,
Steve
#2 Posted : Tuesday, November 6, 2018 3:45:30 AM(UTC)
Just use the export feature in the template section of the shortcuts settings
stevespaw
#3 Posted : Tuesday, November 6, 2018 5:02:30 AM(UTC)
stevespaw
How do I bring the image IN to the template editor??? That is the question.
Steve
#4 Posted : Tuesday, November 6, 2018 5:23:55 AM(UTC)
Not sure we're supposed to do this but you can try adding your image + parameters text file to vMix sub folder called "shortcuts\diagrams"
These files are "read-only"
stevespaw
#5 Posted : Tuesday, November 6, 2018 8:17:24 AM(UTC)
stevespaw
No luck with that method :-(
Steve
