Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
I thought for sure I had done this before, but now I cannot find out how to do this. I need to create a Loadable Template for a custom keyboard and another project a custom Midi controller.
I have a PNG images of the devices, I have created shortcuts. How can I create a template for them? And save for distribution. Is this possible?
Thanks, Steve
Just use the export feature in the template section of the shortcuts settings
How do I bring the image IN to the template editor??? That is the question.
Steve
Not sure we're supposed to do this but you can try adding your image + parameters text file to vMix sub folder called "shortcuts\diagrams" These files are "read-only"
Originally Posted by: DWAM  Not sure we're supposed to do this but you can try adding your image + parameters text file to vMix sub folder called "shortcuts\diagrams" These files are "read-only" No luck with that method :-( Steve
