attilio18
#1 Posted : Thursday, October 25, 2018 12:40:05 AM(UTC)
attilio18
Hi, I created this configuration to build a perfect PC and use it with Vmix.
I wanted to know from you if everything is compatible with vmix.
Thanks a lot.
I use the Blackmagic quad2. foto componenti pc.jpg (552kb) downloaded 4 time(s).
#2 Posted : Thursday, October 25, 2018 1:30:32 AM(UTC)
It's better to have several disks
a small SSD for system 250GB
a medium SSD for projects data 500GB
a big and fast SSD for recordings 1TB
a very big and very fast M2 NVME for multirec and/or instant replay if you plan to do this. 2TB or more
Guillaume
thanks 3 users thanked DWAM for this useful post.
mjgraves on 10/25/2018(UTC), attilio18 on 10/25/2018(UTC), PFBM on 10/25/2018(UTC)
attilio18
#3 Posted : Thursday, October 25, 2018 8:00:05 PM(UTC)
attilio18
Thank you,
Guillaume
In fact, that ssd is reserved only for the operating system ..
I have not put the other SSDs on the list ..
Thank you for your suggestion.
But in total the components seem compatible to you
work better with Vmix?
#4 Posted : Thursday, October 25, 2018 8:38:17 PM(UTC)
I have no experience with any of the components you indicate so I wouldn't say. It "seems" OK.
Please refer to the reference systems page on vMix website or contact a vMix Authorized Reseller in your country if you want to make sure to buy a perfect computer for vMix.
As far as I'm concerned, I have always built my own systems based on vMix requirements with great success.
1TB SSD for system only is a waste imho. Use standard Sata SSD for this. Keep the best and fastest technologies for what needs them.
