Hi, I created this configuration to build a perfect PC and use it with Vmix. I wanted to know from you if everything is compatible with vmix. Thanks a lot. I use the Blackmagic quad2.  foto componenti pc.jpg (552kb) downloaded 4 time(s).
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
It's better to have several disks
a small SSD for system 250GB a medium SSD for projects data 500GB a big and fast SSD for recordings 1TB a very big and very fast M2 NVME for multirec and/or instant replay if you plan to do this. 2TB or more
Guillaume
 3 users thanked DWAM for this useful post.
Thank you, Guillaume In fact, that ssd is reserved only for the operating system .. I have not put the other SSDs on the list .. Thank you for your suggestion. But in total the components seem compatible to you work better with Vmix?
I have no experience with any of the components you indicate so I wouldn't say. It "seems" OK. Please refer to the reference systems page on vMix website or contact a vMix Authorized Reseller in your country if you want to make sure to buy a perfect computer for vMix.
As far as I'm concerned, I have always built my own systems based on vMix requirements with great success.
1TB SSD for system only is a waste imho. Use standard Sata SSD for this. Keep the best and fastest technologies for what needs them.
