phab
#1 Posted : Tuesday, October 23, 2018 9:32:54 PM(UTC)
phab
Hi all ( i am french),
I have a problem during the record H264High bug record vmix.png (167kb) downloaded 3 time(s). :
Vmix 4k 21.0.0.56 x64
Preset 1920x1080 PAL 50i
Blackmagic ATEM Production 4k / 1920x1080 PAL 50i
Win 7 64bit
Best regard
Phab
#2 Posted : Wednesday, October 24, 2018 2:41:10 AM(UTC)
MP4 only supports progressive recordings
Zetor1980 on 10/24/2018(UTC)
stevespaw
#3 Posted : Wednesday, October 24, 2018 5:32:55 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Not true, we do 1080i 59.94i MP4's all the time.
My guess is the Nvidia card/drivers since he has NVEC selected.
Steve
#4 Posted : Wednesday, October 24, 2018 12:10:51 PM(UTC)
High Profile is not supported on Windows 7. Windows 10 is required.
For interlaced sources, while it is true vMix does send interlaced to the encoder if requested
in the recording settings, all encoders we are aware of that work with vMix (including the NVIDIA hardware encoder)
will deinterlace and record only progressive.
Hope this helps.
thanks 3 users thanked admin for this useful post.
DWAM on 10/24/2018(UTC), stevespaw on 10/24/2018(UTC), mjgraves on 10/25/2018(UTC)
phab
#5 Posted : Thursday, October 25, 2018 4:14:51 AM(UTC)
phab
Thank you Martin and Steven,
I have 3 Panasonic AW H40 SDI (cameras PTZ) and only 1920x1080/50i is accepted with Blackmagic Production 4k (!?).
I use the ffmpeg to solve the problem with H264Hight.
Later, I will update the cameras PTZ to NDI and win 10 to fully use Wmix 4K ;)
Best Regard
Phab
carsco
#6 Posted : Monday, December 3, 2018 9:51:31 AM(UTC)
carsco
Italy
Not true. Mpeg-2 "native" settings does encode interlaced.
Sure.
I use always MPG2 native with interlaced inputs and interlaced outputs (TV use), then I play the record on interlaced machine without problems.
But ONLY with MPG2 windows native encoder, not MPEG2 via FFMPEG.
This is why I was looking for a way to have MPEG2 under Windows10, a few days ago.
#7 Posted : Monday, December 3, 2018 11:18:31 AM(UTC)
Sorry, to clarify I was specifically referring to MP4.
