marcio275
#1 Posted : Monday, August 26, 2013 8:31:19 PM(UTC)
marcio275
Hi, I have problems importing. mov files in 64-bit version says invalid format. The same files in 32-bit version is imported without problems. Any suggestions? thanks
Omar
Ernest Król
#2 Posted : Tuesday, August 27, 2013 7:26:44 AM(UTC)
Ernest Król
since there is no 64bit QuickTime you need to use other format or try to find 64bit DirectShow filter (i.e. http://www.riverpast.com/en/prod/quicktime/)
vmixsupport
#3 Posted : Tuesday, August 27, 2013 7:33:41 PM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 159 time(s) in 72 post(s)
Yes, unfortunately Quicktime doesn't support 64bit. You will need to use the 32bit version of vMix with Mov files.
