Hardware Compatibility
Problems in 64 Bits Version - Quicktime files
Joined: 10/17/2012(UTC) Posts: 8 Location: Junin, Buenos Aires, Argentina
Hi, I have problems importing. mov files in 64-bit version says invalid format. The same files in 32-bit version is imported without problems. Any suggestions? thanks
Omar
Joined: 11/12/2012(UTC) Posts: 58  Location: Tarnów, Poland Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
Rank: Staff
Groups: Registered, Administrators Joined: 12/13/2012(UTC) Posts: 244 Location: Gold Coast, Australia
Thanks: 7 times Was thanked: 160 time(s) in 73 post(s)
Yes, unfortunately Quicktime doesn't support 64bit. You will need to use the 32bit version of vMix with Mov files.
