Joined: 3/8/2016(UTC) Posts: 123 Location: Anniston, Alabama
I'll do my best to brief, but I have a laundry list of feature-sets I'd like to see become reality in vMix IR.
1. - A shortcut that allows the spring loaded outer wheel on such devices as the xKeys 68 Jog/Shuttle to play out selected/last events as follows: Turn the wheel left, the clip plays in reverse...and the further you turn the clip, the faster the clip plays. Same when you turn it to the right - expect the clip plays forward, speeding up the further to the right you turn the wheel. At the center, the clip stops to a still frame.
2. The ability to name the Clip Tabs
3. This is a feature that would likely work system wide across imputs, but for Replay, the ability to incrementally zoom and pan. Now, it's to a fixed point based on your settings. Press a key and that's where the screen moves to. I think the ability to incrementally pan left / right / up / down (X/Y) and Zoom In/Out would allow you to focus in on whether a player's foot was in bounds or a knee was down.
4. More music control within IR. Maybe the ability to assign tracks to specific tabs
Hopefully many will +1 this so we can advance the ability of an already great piece of software. Feel free to add to my list!
 2 users thanked JimJacobs for this useful post.
Joined: 4/4/2016(UTC) Posts: 236  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
+1 I don't use Replay as often as I should. The incremental Zoom Pan is interesting to me the most.
Joined: 11/27/2017(UTC) Posts: 17   Location: Louisville, Kentucky Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
+1 Can be a great aid in replay.
JimJacobs wrote:I'll do my best to brief, but I have a laundry list of feature-sets I'd like to see become reality in vMix IR.
Hopefully many will +1 this so we can advance the ability of an already great piece of software. Feel free to add to my list! +1 from me especially #3. It would be an awesome addition. You might even be able to set it up with xbox controllers. I have tried the blank multi set in inputs and then pre zoomed to different places but not quite what I want. I have thought about making 9 different inputs where I make overlay 1 be a zoomed in area of the screen but none of this works great.
Joined: 11/8/2013(UTC) Posts: 87  Location: Bavaria, Germany Thanks: 6 times Was thanked: 19 time(s) in 10 post(s)
+1 As always when somebody is praying for zoom function in IR. I brought it up many times but unfortunately it is not implemented yet.
Joined: 4/23/2017(UTC) Posts: 1,468  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
faded audio with visual hardcut would be my last piece of awesomeness I'd like to see in the replays
Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 18 times Was thanked: 17 time(s) in 14 post(s)
Originally Posted by: JimJacobs  3. This is a feature that would likely work system wide across imputs, but for Replay, the ability to incrementally zoom and pan. Now, it's to a fixed point based on your settings. Press a key and that's where the screen moves to. I think the ability to incrementally pan left / right / up / down (X/Y) and Zoom In/Out would allow you to focus in on whether a player's foot was in bounds or a knee was down.
Hi Jim, Instead of specifying a value number for zoom, pan or tilt, if you put +=0.1 or -=0.1 as the value, it will increment/decrement the current value, which allows you to zoom, pan and tilt to any position, 1 step at a time. Would this work for you? All the best, Giles.
