vMix Call
Unable to do 1080 call between 2 vMix
Rank:: Advanced Member
Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
Hey looking for some helping troubleshooting this vMix Call issue. I am trying to do a vMix Call with video set to 1080 between 2 vMix PCs. PC 1 has no problem, but the return video from PC 2 won't send video if the resolution being sent is higher than 720p. If I change the return resolution from 1080 to 720, video is sent to PC 1. If I change it back to 1080, PC 1 gets no video.
Both PCs are running the latest version and PC 2 has an upload bandwidth of 20Mbps.
Any idea why this is happening or what I can do to further troubleshoot?
Joined: 3/7/2012(UTC) Posts: 2,686  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ sunkast
What are the specifications of PC 2?
i7-3770K GTX670 16GB RAM
I've done a 1080 vMix Call between both PCs in the past...
Total CPU load is just about 30%. I don't think it has anything to do with the specs for PC2 as I know I had done 1080 calling between the 2 vMix machines when vMix Call came out and I did a bunch of testing.
Joined: 8/11/2018(UTC) Posts: 60   Thanks: 33 times Was thanked: 6 time(s) in 6 post(s)
Was the kind of internet access always the same at the two locations (same hardware firewall if used/internet router and same provider) or did it changed when 1080p was no longer possible?
Same everything. Like I said in my OP, 720 works fine, but as soon as I change the return to 1080, video stops sending.
Looked at some of the call stats and it looks like I am sending out video, but somewhere down the line and by the time it gets to the other vMix machine it looks as if its being throttled.
vMix Call
