Title or ticker in multiple (fonts) languages
Friends i need to run a ticker in 3 languages.
I have tried changing font of particular text but it changes the font of all the text present in the editor. Please help.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
As one currently can not mix fonts within one text field can you not use 3 different tickers ?
Is it possible to have 3 tickers in different languages and then start second after the 1st ends and similarly start third after the second ends and keep on repeating it infinitely
There is no OnCompletion with a ticker so can not use a trigger but I suppose if you have the higher end vMix version one could use a script
CORRECTION there is a trick
Make sure each ticker is set to automaticaly restart on transition Give each ticker a Trigger OnOverlayIn - OverlaInput1In (or whichever you are going to use) - set the input to the next ticker you wantto display and set a delay to the same time as the duration of the ticker itself (1000 = 1 sec) and so on for the next ticker (rinse and repeat)
