himanshu2808
#1 Posted : Saturday, October 6, 2018 1:33:02 PM(UTC)
himanshu2808
Friends i need to run a ticker in 3 languages.
I have tried changing font of particular text but it changes the font of all the text present in the editor. Please help.
#2 Posted : Saturday, October 6, 2018 5:01:42 PM(UTC)
As one currently can not mix fonts within one text field can you not use 3 different tickers ?
himanshu2808
#3 Posted : Sunday, October 7, 2018 1:31:19 AM(UTC)
himanshu2808
Is it possible to have 3 tickers in different languages and then start second after the 1st ends and similarly start third after the second ends and keep on repeating it infinitely
#4 Posted : Sunday, October 7, 2018 2:35:34 AM(UTC)
There is no OnCompletion with a ticker so can not use a trigger but I suppose if you have the higher end vMix version one could use a script
CORRECTION there is a trick
Make sure each ticker is set to automaticaly restart on transition
Give each ticker a Trigger OnOverlayIn - OverlaInput1In (or whichever you are going to use) - set the input to the next ticker you wantto display and set a delay to the same time as the duration of the ticker itself (1000 = 1 sec) and so on for the next ticker (rinse and repeat)
